Ouogoing call to different BRI
m.ronchetti
Hi to all,
I have one CME on 2921 with 4 BRI, I have 2 different ephone-DN user group, I want that a group of user go out with a group of BRI and the other group of user with the others BRI.
group1 -->outgoing--> BRI1-BRI2
group2 -->outgoing--> BRI3-BRI4
how can I do that?
And other question, does not work the put pickup-group (I configure it), any idea why?
Thank
Augusto
dksingh
There are several ways to do it like using voice translations, COR (class or restrictions)
but the easiest will be use two different access codes and use trunkgroup CLI to bundle
the BRIs/voiceports and then reference that trunkgroup in the appropriate dialpeer.
Sorry, but I am not clear on your 2nd ques - can u please elaborate a bit?
Thank I'll try with traslation rules, I prefer have only one access code.
My second question: I have a problem with the pickup-group, I configure on ephone-dn the pickup-group, but not work, any idea, what I have to check?
Augusto
Pl. review following to ensure the config is correct and you are using correct
key sequence to attempt pickup a call.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1092675
HTH.
