Outbound fax fails with cause code 47
i have 2811 voice gateway connecting to sip line and mpls from branches.
and in internal network we have a right fax and call manager
server with h323 connection from gateway.and every thing was fine
yesterday i replaced 2811 with 2951 and imported all the configuration to 2951 from 2811.
every thing was fine till now but today i came to know that outgoing faxes are not working. while incoming is fine.
the outgoing faxes are getting failed with cause code 47 "resource unavailable".
here the debugs are
May 18 07:11:53.234: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:33016223237@192.168.12.5 SIP/2.0
From: <sip:5481@192.168.12.73>;tag=9186950-0-13c4-55013-e30f-1b7dec3b-e30f
To: <sip:33016223237@192.168.12.5>
Call-ID: 7d230e8-0-13c4-55013-e30f-66ea7ecd-e30f
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.12.73:5060;branch=z9hG4bK-e30f-376f58c-641cce71
Contact: <sip:192.168.12.73>
Max-Forwards: 70
User-Agent: Brktsip/6.5.2B5 (Dialogic)
Content-Type: application/sdp
Content-Length: 221
v=0
o=- 2209053116 0879491000 IN IP4 192.168.12.73
s=no_session_name
t=0 0
m=audio 56492 RTP/AVP 0
c=IN IP4 192.168.12.73
a=rtpmap:0 pcmu/8000
m=audio 56492 RTP/AVP 8
a=rtpmap:8 pcma/8000
May 18 07:11:53.238: //-1/0D1A9138A837/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=5481
   ----- ccCallInfo IE subfields -----
   cisco-ani=5481
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=33016223237
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
May 18 07:11:53.238: //-1/0D1A9138A837/CCAPI/cc_api_call_setup_ind_common:
   Interface=0xAE83350, Call Info(
   Calling Number=5481,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=33016223237(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=20, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8665
May 18 07:11:53.238: //-1/0D1A9138A837/CCAPI/ccCheckClipClir:
   In: Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
May 18 07:11:53.238: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 07:11:53.238: :cc_get_feature_vsa malloc success
May 18 07:11:53.238:  cc_get_feature_vsa count is 6
May 18 07:11:53.238: :FEATURE_VSA attributes are: feature_name:0,feature_time:31196600,feature_id:1569
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=33016223237(TON=Unknown, NPI=Unknown))
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/cc_process_call_setup_ind:
   Event=0xAECF738
May 18 07:11:53.238: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 33016223237
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCallSetContext:
   Context=0x103C6A4
   >>>>CCAPI handed cid 8665 with tag 20 to app "_ManagedAppProcess_Default"
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCallProceeding:
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=11, Params=0x103B234, Progress Indication=NULL(0)
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCheckClipClir:
   In: Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=33.T, Called Number=016223237, Digit Strip=FALSE
   Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=016223237(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=5481, Final Destination Flag=TRUE,
   Guid=0D1A9138-BEC1-11E2-A837-C0C5037109AB, Outgoing Dial-peer=11
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5481
   cisco-ani=2505481
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=016223237
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0xAE83350, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=2505481,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=016223237(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May 18 07:11:53.242: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 07:11:53.242: :cc_get_feature_vsa malloc success
May 18 07:11:53.242:  cc_get_feature_vsa count is 7
May 18 07:11:53.242: :FEATURE_VSA attributes are: feature_name:0,feature_time:31193016,feature_id:1570
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccCallSetContext:
   Context=0x103B1E4
May 18 07:11:53.242: //8665/0D1A9138A837/CCAPI/ccSaveDialpeerTag:
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0xAE83350, Call Id=8666
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
May 18 07:11:53.242: //8665/0D1A9138A837/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=8666
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0xAE83350, Tag=0x0, Call Id=8666,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
May 18 07:11:53.242: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 18 07:11:53.242: :cc_free_feature_vsa freeing 1DBF7B0
May 18 07:11:53.242:  vsacount in free is 6
May 18 07:11:53.242: //8665/0D1A9138A837/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 18 May 2013 07:11:53 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
May 18 07:11:53.242: //8665/0D1A9138A837/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:33016223237@192.168.12.5>;tag=F9BCC60-144A
CSeq: 1 INVITE
Reason: Q.850;cause=47
Content-Length: 0
May 18 07:11:53.246: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:33016223237@192.168.12.5 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
May 18 07:11:53.246: //8665/0D1A9138A837/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xAE83350, Tag=0x0, Call Id=8665,
configuration for right fax is
voice translation-rule 5
rule 1 /^33\(.......\)/ /\1/  ---------------7
rule 2 /^33\(.........\)/ /\1/ -------------9
rule 3 /^33\(............\)/ /\1/------------12
rule 4 /^33\(..........\)/ /\1/-------------10
rule 6 /^33\(.............\)/ /\1/----------13
rule 7 /^33\(...........\)/ /\1/-------------11
voice translation-rule 6
rule 1 /^5\(...\)/ /2505\1/
dial-peer voice 11 voip
description **Outgoing FAX to SIP Trunk**
translation-profile outgoing OUT_FAX
destination-pattern 33.T
session protocol sipv2
session target ipv4:10.200.7.157
codec g711alaw
fax protocol pass-through g711alaw
no vad
dial-peer voice 180 voip
description **to FAX SERVER**
destination-pattern 25054[8-9].
session target ipv4:192.168.12.73
codec g711alaw
no vad
dial-peer voice 20 voip
description ***TO-ISP***
translation-profile outgoing OUT-SIP
destination-pattern [^33].T
progress_ind progress enable 8
rtp payload-type cisco-codec-fax-ack 111
rtp payload-type nte 97
session target ipv4:10.200.7.157:5060
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
no vad
Fax call flow is like
ITSP-------[sip]-----------gateway-------[323]-----------------Right Fax server.
thank you
31 Replies 31
Ayodeji Okanlawon
The outogin dial-peer the call is matching is dial-peer 11. This dial-peer is configured for sip...your diagram shows that your right fax is using h323..You should configure a h323 dial-peer to your right fax server
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Aokanlawon,
either it is sip or h323 the outbound fax getting failed.
this is the debug from cisco 2811, this call getting successful, with the same config...
May 18 08:24:08.057: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:334723004@192.168.12.5 SIP/2.0
From: <5481>;tag=91929b0-0-13c4-55013-f4e2-11e55d88-f4e2
To: <334723004>
Call-ID: 7d286e8-0-13c4-55013-f4e2-4a82ae42-f4e2
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.12.73:5060;branch=z9hG4bK-f4e2-3bc93c3-221ea971
Contact: <192.168.12.73>
Max-Forwards: 70
Content-Length: 221
v=0
o=- 2209058165 0155446000 IN IP4 192.168.12.73
s=no_session_name
t=0 0
m=audio 56832 RTP/AVP 0
m=audio 56832 RTP/AVP 8
May 18 08:24:08.065: //745561/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
May 18 08:24:08.065: //-1/24DC0898A2C9/CCAPI/cc_api_display_ie_subfields:
   cisco-username=5481
   cisco-ani=5481
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=334723004
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 18 08:24:08.065: //-1/24DC0898A2C9/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x46E8C084, Call Info(
   Called Number=334723004(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=745561
May 18 08:24:08.065: //-1/24DC0898A2C9/CCAPI/ccCheckClipClir:
May 18 08:24:08.065: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 08:24:08.065: :cc_get_feature_vsa malloc success
May 18 08:24:08.065:  cc_get_feature_vsa count is 21
May 18 08:24:08.065: :FEATURE_VSA attributes are: feature_name:0,feature_time:1193440416,feature_id:327824
May 18 08:24:08.069: //745561/24DC0898A2C9/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=334723004(TON=Unknown, NPI=Unknown))
May 18 08:24:08.069: //745561/24DC0898A2C9/CCAPI/cc_process_call_setup_ind:
   Event=0x472368A8
May 18 08:24:08.073: //745561/24DC0898A2C9/CCAPI/ccCallSetContext:
   Context=0x47A33EE0
May 18 08:24:08.073: //745561/24DC0898A2C9/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 745561 with tag 20 to app "_ManagedAppProcess_Default"
May 18 08:24:08.073: //745561/24DC0898A2C9/CCAPI/ccCallProceeding:
May 18 08:24:08.077: //745561/24DC0898A2C9/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=11, Params=0x47B72AE8, Progress Indication=NULL(0)
May 18 08:24:08.077: //745561/24DC0898A2C9/CCAPI/ccCheckClipClir:
   Destination Pattern=33.T, Called Number=4723004, Digit Strip=FALSE
May 18 08:24:08.081: //745561/24DC0898A2C9/CCAPI/ccCallSetupRequest:
   Called Number=4723004(TON=Unknown, NPI=Unknown),
   Guid=24DC0898-BECB-11E2-A2C9-D064EA6472F2, Outgoing Dial-peer=11
May 18 08:24:08.081: //745561/24DC0898A2C9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5481
   cisco-ani=2505481
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4723004
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 18 08:24:08.081: //745561/24DC0898A2C9/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46E8C084, Interface Type=3, Destination=, Mode=0x0,
   Called Number=4723004(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
May 18 08:24:08.081: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 08:24:08.081: :cc_get_feature_vsa malloc success
May 18 08:24:08.081:  cc_get_feature_vsa count is 22
May 18 08:24:08.081: :FEATURE_VSA attributes are: feature_name:0,feature_time:1193439552,feature_id:327825
May 18 08:24:08.081: //745562/24DC0898A2C9/CCAPI/ccIFCallSetupRequestPrivate:
May 18 08:24:08.081: //745562/24DC0898A2C9/CCAPI/ccCallSetContext:
   Context=0x47B72A98
May 18 08:24:08.081: //745561/24DC0898A2C9/CCAPI/ccSaveDialpeerTag:
May 18 08:24:08.085: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <334723004>
Date: Sat, 18 May 2013 08:24:08 GMT
CSeq: 1 INVITE
Content-Length: 0
May 18 08:24:08.089: //745562/24DC0898A2C9/CCAPI/cc_api_call_proceeding:
   Interface=0x46E8C084, Progress Indication=NULL(0)
May 18 08:24:08.093: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4723004@10.200.7.157:5060 SIP/2.0
Via: SIP/2.0/UDP 10.66.200.214:5060;branch=z9hG4bK2DA971CC5
Remote-Party-ID: <2505481>;party=calling;screen=no;privacy=off
To: <4723004>
Call-ID: 24E0EA70-BECB11E2-A2CED064-EA6472F2@10.66.200.214
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 618399896-3200979426-2731135076-3932451570
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1368865448
Contact: <2505481>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 7061 7307 IN IP4 10.66.200.214
s=SIP Call
c=IN IP4 10.66.200.214
t=0 0
m=audio 18146 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
May 18 08:24:08.813: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <4723004>
CSeq: 101 INVITE
Content-Length: 0
May 18 08:24:10.161: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Record-Route: <10.200.7.157:5060>
To: <4723004>;tag=sbc0804dcedese7-CC-51
CSeq: 101 INVITE
Contact: <4723004>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Content-Length: 133
v=0
o=- 406816 406816 IN IP4 10.200.7.157
s=SBC call
c=IN IP4 10.200.7.157
t=0 0
m=audio 57706 RTP/AVP 8
May 18 08:24:10.161: //745562/24DC0898A2C9/CCAPI/cc_api_call_alert:
   Interface=0x46E8C084, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
May 18 08:24:10.165: //745561/24DC0898A2C9/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
May 18 08:24:10.177: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <334723004>;tag=E7634F1C-1912
CSeq: 1 INVITE
Remote-Party-ID: <4723004>;party=called;screen=no;privacy=off
Contact: <4723004>
Content-Length: 0
May 18 08:24:15.269: //745555/1DFE380DA2BF/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
May 18 08:24:15.269: //745555/1DFE380DA2BF/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x46E7A584, Call Id=745555
May 18 08:24:15.273: //745554/1DFE380DA2BF/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=745554
ASICO-RYD#
ASICO-RYD#
ASICO-RYD#u all
All possible debugging has been turned off
ASICO-RYD#
please send your sh run on the 2900 gateway
Hi aokanlawon,
here the config is attached
Mohammed...can you configure this on dial-peer 11
dtmf-relay rtp-nte
If the call fails again..please send debug ccsip all..attach it to the thread
this is cisco 2811 router dial-peer
description **Outgoing Call to SIP Trunk**
codec g711alaw
no vad
and the dtmf command not required for this.....and the fax is working fine with this,why not with 2951
If you want to know why, then you should send me debug ccsip all...Once you have done the test then please apply the command...test again
can i add
rule 8 /^33\(.*\)/ /\1/
to send any number starting from 33 to ITSP.instead of the 7 rules in prfile 5
rule 5 /^33\(..........\)/ /\1/
     rule 1 /^33\(.*\)/ /\1/
and for the debug ccsip all,
i have to wait for the work hours finish, as currently i switched back to 2811 for the fax problem,
i can provide you the details after 1 hour as our working hours finished.
Yes you can do that. Thats much better. Ok let me know when you do the test...
this is the order I need the test
1. switch o the 2951, enable debug ccsip all and test, collect the logs
2. configure the dtmf-relay rtp-nte ont he dial-peer 11, test and collect the logs too
ok, i will send the logs as you instructed,
i got a doubt, may be it looks very silly to you.....
i have the outgoing dial-peer 11 which strips 33
codec g711alaw
no vad
and here i am matching the translation-rule which comapres the numbers unless its starts with 33
is it right or shall i remove that and specify only
     rule 1 /\(.*\)/ /\1/
so that each and every number can be matched...
here the ccsip all  and the other is voice ccapi inout
First of all the debug ccsip all doesnt contain the call in it. Please do the ff:
esnure you send your logs to the router buffer by using the steps below:
Router#configuration terminal
Router(config)#no logging console
Router(config)#no logging monitor
Router(config)#service timestamps debug datetime msec
Router(config)#logging buffered 5000000 debugging
Router(config)#service sequence
Router(config)#no logging rate-limit
Router(config)#exit
Router#term len 0
Router#clear log
Turn on these debugs.
debug ccsip all
Place a call.
Router# show log
When you do the show log, you will need to capture the entire output to a file, which varies depending on how you connect to the device. You can use putty to obtain the logs
Second have you changed the dtmf on dial-peer 11...??
This debug voip ccapi looks successful. This call matches dial-peer 20..what is this test for?
i am really sorry that there is no fax call in the debug.
i switched to 2951 from 2811 and send a fax to get the debug, it took some time meanwhile, other employees who were warking might did some calls which got captured, as they are going through dial-peer 20,
and i shift the connections back to 2811 and isloated the router 2951 from network and uploaded the debugs and came home, now i have no access to the router as it is not on network.
i can provide the debugs tommorrow.
i captured another debug but it didn't get saved, just the ccapi inout file "debug new" contains the call, my fax number is 2505481
Pretty much if you want to achieve Fax between the Cisco CUBE and Fax Server, use SIP all the way and make sure that you setup t.38 correctly on the CUBE, since may ITSP will use t.38, or G711 passthrough, in such case you have to setup the CUBE to connect g711 all the way, so the Fax tones are transmitted over the RTP stream...
In addition, please make sure to capture a complete debug, with all the signaling from Fax to CUBE and from CUBE to ITSP.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
