05-18-2013 01:57 AM - edited 03-16-2019 05:23 PM
i have 2811 voice gateway connecting to sip line and mpls from branches.
and in internal network we have a right fax and call manager
server with h323 connection from gateway.and every thing was fine
yesterday i replaced 2811 with 2951 and imported all the configuration to 2951 from 2811.
every thing was fine till now but today i came to know that outgoing faxes are not working. while incoming is fine.
the outgoing faxes are getting failed with cause code 47 "resource unavailable".
here the debugs are
May 18 07:11:53.234: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:33016223237@192.168.12.5 SIP/2.0
From: <sip:5481@192.168.12.73>;tag=9186950-0-13c4-55013-e30f-1b7dec3b-e30f
To: <sip:33016223237@192.168.12.5>
Call-ID: 7d230e8-0-13c4-55013-e30f-66ea7ecd-e30f
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.12.73:5060;branch=z9hG4bK-e30f-376f58c-641cce71
Contact: <sip:192.168.12.73>
Max-Forwards: 70
User-Agent: Brktsip/6.5.2B5 (Dialogic)
Content-Type: application/sdp
Content-Length: 221
v=0
o=- 2209053116 0879491000 IN IP4 192.168.12.73
s=no_session_name
t=0 0
m=audio 56492 RTP/AVP 0
c=IN IP4 192.168.12.73
a=rtpmap:0 pcmu/8000
m=audio 56492 RTP/AVP 8
a=rtpmap:8 pcma/8000
May 18 07:11:53.238: //-1/0D1A9138A837/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=5481
----- ccCallInfo IE subfields -----
cisco-ani=5481
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=33016223237
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
May 18 07:11:53.238: //-1/0D1A9138A837/CCAPI/cc_api_call_setup_ind_common:
Interface=0xAE83350, Call Info(
Calling Number=5481,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=33016223237(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=20, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8665
May 18 07:11:53.238: //-1/0D1A9138A837/CCAPI/ccCheckClipClir:
In: Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
May 18 07:11:53.238: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 07:11:53.238: :cc_get_feature_vsa malloc success
May 18 07:11:53.238: cc_get_feature_vsa count is 6
May 18 07:11:53.238: :FEATURE_VSA attributes are: feature_name:0,feature_time:31196600,feature_id:1569
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=33016223237(TON=Unknown, NPI=Unknown))
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/cc_process_call_setup_ind:
Event=0xAECF738
May 18 07:11:53.238: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 33016223237
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCallSetContext:
Context=0x103C6A4
>>>>CCAPI handed cid 8665 with tag 20 to app "_ManagedAppProcess_Default"
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCallProceeding:
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=11, Params=0x103B234, Progress Indication=NULL(0)
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccCheckClipClir:
In: Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Destination Pattern=33.T, Called Number=016223237, Digit Strip=FALSE
Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=016223237(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=
Account Number=5481, Final Destination Flag=TRUE,
Guid=0D1A9138-BEC1-11E2-A837-C0C5037109AB, Outgoing Dial-peer=11
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=5481
cisco-ani=2505481
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=016223237
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
May 18 07:11:53.238: //8665/0D1A9138A837/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0xAE83350, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=2505481,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=016223237(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May 18 07:11:53.242: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 07:11:53.242: :cc_get_feature_vsa malloc success
May 18 07:11:53.242: cc_get_feature_vsa count is 7
May 18 07:11:53.242: :FEATURE_VSA attributes are: feature_name:0,feature_time:31193016,feature_id:1570
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccCallSetContext:
Context=0x103B1E4
May 18 07:11:53.242: //8665/0D1A9138A837/CCAPI/ccSaveDialpeerTag:
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0xAE83350, Call Id=8666
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
May 18 07:11:53.242: //8665/0D1A9138A837/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=8666
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
May 18 07:11:53.242: //8666/0D1A9138A837/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0xAE83350, Tag=0x0, Call Id=8666,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
May 18 07:11:53.242: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 18 07:11:53.242: :cc_free_feature_vsa freeing 1DBF7B0
May 18 07:11:53.242: vsacount in free is 6
May 18 07:11:53.242: //8665/0D1A9138A837/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 18 May 2013 07:11:53 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
May 18 07:11:53.242: //8665/0D1A9138A837/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:33016223237@192.168.12.5>;tag=F9BCC60-144A
CSeq: 1 INVITE
Reason: Q.850;cause=47
Content-Length: 0
May 18 07:11:53.246: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:33016223237@192.168.12.5 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
May 18 07:11:53.246: //8665/0D1A9138A837/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0xAE83350, Tag=0x0, Call Id=8665,
configuration for right fax is
voice translation-rule 5
rule 1 /^33\(.......\)/ /\1/ ---------------7
rule 2 /^33\(.........\)/ /\1/ -------------9
rule 3 /^33\(............\)/ /\1/------------12
rule 4 /^33\(..........\)/ /\1/-------------10
rule 6 /^33\(.............\)/ /\1/----------13
rule 7 /^33\(...........\)/ /\1/-------------11
voice translation-rule 6
rule 1 /^5\(...\)/ /2505\1/
dial-peer voice 11 voip
description **Outgoing FAX to SIP Trunk**
translation-profile outgoing OUT_FAX
destination-pattern 33.T
session protocol sipv2
session target ipv4:10.200.7.157
codec g711alaw
fax protocol pass-through g711alaw
no vad
dial-peer voice 180 voip
description **to FAX SERVER**
destination-pattern 25054[8-9].
session target ipv4:192.168.12.73
codec g711alaw
no vad
dial-peer voice 20 voip
description ***TO-ISP***
translation-profile outgoing OUT-SIP
destination-pattern [^33].T
progress_ind progress enable 8
rtp payload-type cisco-codec-fax-ack 111
rtp payload-type nte 97
session target ipv4:10.200.7.157:5060
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
no vad
Fax call flow is like
ITSP-------[sip]-----------gateway-------[323]-----------------Right Fax server.
thank you
05-19-2013 02:03 AM
Hi Jorqe,
the same config is working for cisco 2811, and the faxes are going without any problem.
but for 2951 its getting failed with cause code 47 ' resourse unavailable" what does that means...
05-19-2013 05:47 AM
Hi aokanlawon,
i have a doubt that does pvdm 3 supports fax calls,
please can you check this
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/pvdm3_config.html
The PVDM3 card can only be installed and used on the following Cisco voice gateway routers:
•Cisco 2901 and Cisco 2911 (each router supports up to two PVDM3 modules)
•Cisco 2921 and Cisco 2951 (each router supports up to three PVDM3 modules)
•Cisco 3925 and Cisco 3945 (each router supports up to four PVDM3 modules)
•Cisco 3925E and Cisco 3945E (each router supports up to three PVDM3 modules)
All codecs that are supported on the PVDM2 are supported on the PVDM3, except that the PVDM3 does not support the G.723 (G.723.1 and G.723.1A) codecs. The PVDM2 can be used to provide G.723 codec support or the G.729 codec can be as an alternative on the PVDM3.
The PVDM3 DSP does not support Cisco Fax Relay. The PVDM2 (5510 DSP) does support Cisco Fax Relay.
The coexistence of PVDM2 and PVDM3 modules on the same motherboard is not supported. If these two modules are installed on the same motherboard, the PVDM2 is shut down.
05-19-2013 09:14 AM
05-19-2013 11:31 AM
Ok..Here is what is going on..from the logs
The invite from dialogic comes with multiple m-lines..
+++Invitae has two mlines.++++
v=0
o=- 2209181167 0295969000 IN IP4 192.168.12.73
s=no_session_name
t=0 0
m=audio 56420 RTP/AVP 0
m=audio 56420 RTP/AVP 8
++ From the logs cisco CUBE selected the first media in the top most m-line which is g711ulaw (this is what is referred to as codec 5 in the log)
006752: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_CopyChannelInfoToCodecList: Codec added 5
006753: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Check between Equalset & Subset..
006754: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/codec_found:
Codec to be matched: 5
+++No the outbound dial-peer 11 has codec set to use g711alaw (this is called codec 6) and you can see the gateway saying no codec match found++
006755: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/codec_found: No match for the codecs found..
006756: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: No match found. Just break..
006757: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Check between disjointset & Subset..
006758: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/codec_found:
006759: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/codec_found: No match for the codecs found..
006760: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Match found. Continue for next codec..
006761: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: This is Disjoint set
006762: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPICodecTranscoder: Codec set type is 3
006763: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPICodecTranscoder: Disjoint set or Subset w/ offer-all. For DO call, offer-all is NO-OP..Continue to reserve xcoder resource..
006764: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_ReserveXcoderResource: Consider codec 6, 5 for xcoder reservation
006765: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/codec_found:
006766: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/codec_found: No match for the codecs found..
006767: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/ccsip_get_xcode_resource: cap_mask1=2, cap_mask2=1
006768: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_ReserveXcoderResource: Xcoder reservation got fail for all the possible combination
006769: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/sipSPI_ipip_vcc_ReserveXcoderResource: After xcoder reservation, status is: xcoder_codec = -1, peer_xcoder_codec = -1, stream = 0, peer_stream = 0
006770: May 19 15:20:33.084: //9234/7B8074E2ABF0/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:47, category:182
++For this call to work, the gateway needs to allocate a xcoder, which it coudnlt and the call failed++++
NB: we have not even gotten to fax negotiation because the voice call has not been established...
So to resolve this problem you need to configure G711ulaw on dial-peer 11. If your provider doesnt support g711ulaw then you will need to change the config on your right fax server to only send G711alaw in the media line of the sip invite
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
05-19-2013 03:14 PM
Hi Aokanlawon,
Thanks a lot for your efforts,
that was a lengthy task to go through all the logs.
i will try the solution and hope will work fine.
instead of hard coding the codec can i define another codec class
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
and change the dial-peer like below
description **Outgoing Call to SIP Trunk**
voice-class codec 2
fax protocol pass-through g711ulaw
no vad
and the translation-rule is like
rule 1 /^33\(.*\)/ /\1/
if it doesn't work, will change the codec to g711alaw on fax server...
Thank you once againg....
05-19-2013 03:21 PM
Yes you can do that...As long as your provider supports G711ulaw
05-19-2013 03:28 PM
thank you aokanlawon,
will try and update the result tomorrow...
but why its not supporting on 2951 while the 2811 has the same config with codec g711alaw
05-20-2013 08:42 AM
05-20-2013 04:12 PM
Enable:
voice iec syslog
And look if by any chance you get an error message saying something like:
No DSP found locally or globally
If you get this error, please enter:
conf t
voice service pots
fax rate disable
This only happens with PVDM3
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
05-20-2013 04:24 PM
Hi Jorqe,
Thnak you for reply,
i will try tomorrow and post the results, hoping it will work.
05-20-2013 05:45 PM
Jorge there are no pots dial-peer in this setup..Its purely ip to ip..Faxes are connected to a right fax server and the PSTN connectivity uses SIP Trunks
05-20-2013 05:44 PM
I dont know what these debugs are for. I dont see any fax negotiation in this logs...Please dont use debug ccsip all again we dont need it for now..
When you do a test call now only use debug ccsip messages and include the calling and called number..
When you say some fax fail does it mean that some work? Send a debug ccsip message and debug voip ccapi inout for faxes that fail
05-21-2013 09:20 AM
05-21-2013 12:06 PM
Mohammed,
Before you send logs please take a few minuts to check that the calls exist in the log...The called number do not exist in this log..I spend too much time looking for calls that do nto exist. In the future I wont be doing that..So please do your home work
05-21-2013 05:37 PM
Hi Mr.Deji,
i am extremly sorry for the logs,
i think the calls didn't make even to the router,i did many calls,some of which got succeeded and some got failed.
the calls which got failed are not in debugs.
i didn't understand why this happend.
i assure you from next time i will cautiously check the logs before posting.
Thank you very much and once again i apologies for the mistake.
