Outgoing call take long time to etablish
Nirwana Support
I have a little problem with my UC540 (last os update ok). When I make an outgoing call, I type the prefix 0 for outgoing and make the others numbers but it take 12 to 15second to execute the call and get the first ring (in my phone outgoing planification all is ok, configured with SIP first) it's a very long delay. I make another test with 9 prefix for analogical outgoing, delay is correct it take 5-6 second to have the first ring. Someone have an idea ? Is there a configuration somewhere to change this delay ?
25 Replies 25
acampbell
This sounds like an overlapping dial plan issue and you are having to wait for a 15 second timer (EG H323 T302) to expire before sending to line.
Can we see your dial peer configs
Alex
Regards, Alex. Please rate useful posts.
Hhi, sorry but I'm new user of UC540, how can I obtain the dial peer configs on telnet ? "show dial-peer voice" ? My UC540 is 90% configured with CCA and some custom with command line
telnet to your device
then use the ena comand and enter your password
Issue this command and trap the output
show run | beg dial-peer
Alex
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 31
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 32
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 33
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 34
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description catch all dial peer for BRI/PRI^T
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 19
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 20
b2bua
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 18
b2bua
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*France*International Calls**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 000T
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*France*International Freecall**
preference 5
destination-pattern 000800T
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*France*Geographic Numbering**
preference 5
destination-pattern 00[1-5]........
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*France*Fixed NGN (to 31/12/2008)**
preference 5
destination-pattern 0087.......
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
description **CCA*France*Numero Vert**
preference 5
destination-pattern 0080.......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*France*Numero Azur**
preference 5
destination-pattern 0081.......
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
description **CCA*France*Nemero Indigo**
preference 5
destination-pattern 00890......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
corlist outgoing call-national-plus
description **CCA*France*Premium**
preference 5
destination-pattern 0089.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 009........
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
description **CCA*France*Value Added Services**
preference 5
destination-pattern 03...
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*France*Police (17) Fire (18) Ambulance (19)**
preference 5
destination-pattern 01[578]
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1[578]
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
description **CCA*France*3 Digit Emergency equivalents**
preference 5
destination-pattern 011[2459]
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 11[2459]
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
description **CCA*France*Directory Enquiries**
preference 5
destination-pattern 0118...
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_FXO
description **CCA*France*Network access codes**
preference 5
destination-pattern 010..
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
description **CCA*France*Indirect Access**
preference 5
destination-pattern 016..
forward-digits all
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (Generic SIP Trunk Provider) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1021 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1022 voip
description **CCA*France*Mobile**
preference 1
destination-pattern 006........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1026 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1027 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1028 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1029 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1030 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1031 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1032 voip
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1033 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1034 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1035 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1036 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1037 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3005 voip
description Claude
translation-profile incoming Claude_Called_9
incoming called-number 1mynumber1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3006 voip
description Jorge
translation-profile incoming Jorge_Called_10
incoming called-number 1mynumber2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3007 voip
description Sebastien
translation-profile incoming Sebastien_Called_11
incoming called-number 1mynumber3
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3011 voip
description Standard-AA
translation-profile incoming Standard-AA_Called_15
incoming called-number 1myallnumber
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3000 voip
description GroupeNirwana-BG
translation-profile incoming GroupeNirwana-BG_Called_4
incoming called-number 1mybasednumber
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 76 pots
trunkgroup ALL_FXO
description **CCA*France*Mobile2**
preference 5
destination-pattern 007........
forward-digits all
no sip-register
dial-peer voice 1038 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3001 voip
description Atelier
translation-profile incoming Atelier_Called_5
incoming called-number 1mynumber4
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1110 pots
preference 9
destination-pattern 1mynumber4
port 0/0/0
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
description **CCA*France*Techdata**
preference 5
destination-pattern 00825......
forward-digits all
no sip-register
dial-peer voice 1039 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup ALL_FXO
description **CCA*France*Mobile - Fixe**
preference 5
destination-pattern 90[1-7]........
forward-digits all
no sip-register
no dial-peer outbound status-check pots
sip-ua
credentials username myusername password 7 mycryptedpassowrd realm sip3.voip-centrex.net
authentication username myusername password 7 mycryptedpassword
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:194.98.81.144 expires 120
sip-server ipv4:194.98.81.144
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone SPA525-Encryption-key NirW2536
service phone SPA525-wifi-on yes
service phone SPA525-protocol SPCP
service phone SPA525-auto-detect-sccp yes
service phone SPA525-http-write yes
service phone SPA525-SSID NirwanaVoice
service phone SPA525-readonly no
service phone SPA525-Encryption-type WPA2_PSK
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message NirWana
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale U4 load CME-locale-fr_FR-French-8.1.2.1.tar
network-locale U4
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-6
load 501G spa50x-30x-7-4-6
load 502G spa50x-30x-7-4-6
load 504G spa50x-30x-7-4-6
load 508G spa50x-30x-7-4-6
load 509G spa50x-30x-7-4-6
load 525G2 spa525g-7-4-6
load 301 spa50x-30x-7-4-6
load 303 spa50x-30x-7-4-6
time-zone 23
time-format 24
date-format dd-mm-yy
keepalive 30 auxiliary 4
voicemail 19
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 mycryptedpassword
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 0.T
transfer-pattern 6.. blind
secondary-dialtone 0
night-service day Sun 19:30 08:30
night-service day Mon 19:30 08:30
night-service day Tue 19:30 08:30
night-service day Wed 19:30 08:30
night-service day Thu 19:30 08:30
night-service day Fri 19:30 08:30
night-service day Sat 19:30 08:30
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  294
number 0180866866 no-reg both
description SIP Main Number registration
preference 10
ephone-dn  295  dual-line
number 23 secondary 182701673 no-reg both
label Jorge
description Jorge T
name Jorge T
call-forward busy 19
call-forward noan 19 timeout 20
ephone-dn  296  dual-line
number 22 secondary 182701672 no-reg both
label Sebastien
description Sebastien G
name Sebastien G
ephone-dn  297  dual-line
number 21 secondary 182701671 no-reg both
label Claude
description Claude L
name Claude L
ephone-dn  298
number 6.. no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 19
ephone-dn  299
number A801.. no-reg primary
mwi off
ephone-dn  300
number A800.. no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address E8B7.4815.5F05
ephone-template 16
max-calls-per-button 2
username "SG" password mypassword
type 504G
button  1:296 2m297 3m295
ephone  7
mac-address 1CDF.0F4A.2B81
ephone-template 16
username "JT" password mypassword
type 504G
button  1:295 2m297 3m296
ephone  8
mac-address 4055.39A2.6406
ephone-template 16
username "CL" password mypasword
type 525G2 addon 1 500S
button  1:297 4m296 5m295
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.0 (1). Thu Jun 09 11:35:41 CEST 2011^^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
abukuru95
Level 3
Level 3
Hi Nirwanna, try this command on your CME configuration lower the seconds value to 5000.the default is 15000 seconds
h225 timeout t302 seconds
try it on the outgoing dial peers.
rate if this helps !!
good luck
I found where to type this commande
config
voice service voip
h323
h225 timeout t302 5
but nothing change, don't know if configuration has been apply or not
i make:
copy system:running-config nvram:startup-config
sorry but in command line i don't really know the command, i never use UC540 (or other telephony stuff) before, my boss give me this one and say make it work...
The problem here is that you are using SIP dial peers as your 1st choice (preference 1) for you destinations starting with "0"
The T302 timer is related to H323/H225 not SIP
I am still looking at the dial peers
Just for you to note
Most changes you make in the config are dynamic
copy run start
Saves the config.
no it wont help.
the CME process the digits when it finds the closest match.
in your config you have something like
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
here the router will have to wait for the inter digit timeout value before processing the calls because of the T.
you will have to really define in a better way the destination pattern used by the dial peer that is to process the outgoing call.
e.g you would use for a number like 0033 2569 83563
something like destination-pattern 000332569.....
forward digits 8
you will have to give me an example of a number that you are dialing so that i can see which destination pattern is used.
ok, here an example:
Cellphone: 0 0613133320
ClassicPhone: 0 0169202776
In bold the prefix to go out define in my UC540
Looking at your classic phone number
This matches 2 dial peers
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
The first match would be SIP (peer 1025) as it has PREFERENCE 1
Is the SIP trunk actually UP ?
Yes SIP is UP , peer 1025 is the SIP, peer 60 is the analogical line on my FXO 0, i make a little clean in my outgoing plan in the same time, some rules are useless for me
Can we see what this part of the SIP dial peer config is doing
This will appear at the top of your router config.
show run | beg voice translation
You will see it shows the rule and profiles.
We need to see the profile and the rules that are applied
Here:
voice translation-rule 4
rule 1 /myphonenumber/ /53/
voice translation-rule 5
rule 1 /myphonenumber4/ /31/
voice translation-rule 9
rule 1 /myphonenumber1/ /21/
voice translation-rule 10
rule 1 /myphonenumber3/ /23/
voice translation-rule 11
rule 1 /myphonenumber2/ /22/
voice translation-rule 15
rule 1 /myphonenumber0/ /20/
voice translation-rule 410
rule 1 /^0\(.*\)/ /\1/
rule 2 /^9\(.*\)/ /\1/
rule 15 /^..$/ /myphonenumber/
voice translation-rule 411
rule 1 /^0\(.*\)/ /ABCD0\1/
rule 2 /^9\(.*\)/ /ABCD9\1/
rule 3 /^\(..\)$/ /ABCD\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 15 /^..$/ /0180866866/
voice translation-rule 1112
rule 1 /^0/ //
rule 2 /^9/ //
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
if you want more i can add more
Please,
Can you include the voice translation profiles
They should come in to the display after the rules
