Booting Issue with 7942G
I am getting an error while my phone boots 7942G
I have tried those commands but nothing happen
no ip dhcp conflict logging
no ip dhcp ping packets
Please find the attached files with this post
Please Suggest
Is it just 1 phone or all phones that don't register?
The load under telephony service doesn't look right, it should be
load 7942 SCCP42.8-4-2S
You could also add an alias to your tftp entries
tftp-server flash:jar42sccp.8-4-1-23.sbn alias jar42sccp.8-4-1-23.sbn
tftp-server flash:SCCP42.8-4-2S.loads alias SCCP42.8-4-2S.loads
tftp-server flash:term42.default.loads alias term42.default.loads
tftp-server flash:apps42.8-4-1-23.sbn alias apps42.8-4-1-23.sbn
tftp-server flash:cnu42.8-4-1-23.sbn alias cnu42.8-4-1-23.sbn
tftp-server flash:cvm42sccp.8-4-1-23.sbn alias cvm42sccp.8-4-1-23.sbn
tftp-server flash:term62.default.loads alias term62.default.loads
tftp-server flash:sccp.23.sbn alias sccp23.sbn
tftp-server flash:term41.default.loads alias term41.default.loads
tftp-server flash:dsp42.8-4-1-23.sbn alias dsp42.8-4-1-23.sbn
Don't forget to type:
telephony-service
create cnf-files
HTH,
Justin
5 Replies 5
Justin Brenton
Level 4
Level 4
Hi Syed,
Can you post your configuration?
Justin
Dear Mr.Justin Brenton,
Please find the attached config for CME
SH RUN
Building configuration...
Current configuration : 22014 bytes
! Last configuration change at 19:42:45 UAE Tue Jul 26 2011
! NVRAM config last updated at 19:55:47 UAE Tue Jul 26 2011
version 15.1
hostname xxxxxxxxxxxxxxx
boot-start-marker
boot-end-marker
card type e1 0 0
enable password xxxxx
no aaa new-model
clock timezone UAE 4 0
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
ip dhcp excluded-address x.x.x.x x.x.x.x
ip dhcp pool VOICE
   network x.x.x.x x.x.x.x
   default-router x.x.x.x
   option 150 ip x.x.x.x
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2469773702
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2469773702
revocation-check none
crypto pki certificate chain TP-self-signed-2469773702
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32343639 37373337 3032301E 170D3131 30373236 31313531
30345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34363937
37333730 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
81009665 ACB84EE9 39BD3FBD EB9320DB 8251E40D 9692DA92 BEB184FD 8EEDD11D
BB94A6A4 90B8ED45 9A06942B 3324A3BE FBC39E16 8FE4D8A4 480BE3D0 201F876F
7B88EC95 394192CD 7FA65406 DE67BCAB 2A277205 948780C5 F1A3750F 42E03306
1DB5754C 0A2882EA DB28C594 FD97553B E4C894BB 4382ECDB 8837D0D0 F37067FC
2E3F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
   551D2304 18301680 14AEFB57 F62AAB8D 1EFD849E 2D1369F6 88D4765B FF301D06
03551D0E 04160414 AEFB57F6 2AAB8D1E FD849E2D 1369F688 D4765BFF 300D0609
2A864886 F70D0101 04050003 81810061 F1230438 33B48232 04A009FB 0E32B0DA
81AD23CD C9EE8206 86A8C025 C993A07A CE4C1407 86DC8883 218A266F 63BB8792
441AD261 D284D0DD EDCEA730 CB20BCE1 8A11BD04 23439EFD E93256E9 12D34485
684C6401 9612C9FB 4109FD90 E4B05D3C 806157B1 607AAFD7 25FC7256 4A59525B
CBDC2AA3 7EBFFA39 56E9123B 20CE3D
          quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice class codec 1
codec preference 1 g711ulaw
voice hunt-group 1 parallel
list 711,712,713
timeout 30
pilot 1
voice translation-rule 1
rule 1 /^............$/ /9000/
rule 2 /^............$/ /9/
rule 3 /^............$/ /904/
voice translation-rule 2
rule 1 /\(.*\)/ /9\1/
voice translation-rule 9
rule 1 /^911$/ /911/
rule 2 /^9\(.*\)/ /\1/
rule 3 /^[0-9]+/ /9&/
rule 4 /^............$/ /9000/
rule 5 /\(.*\)/ /00\9/
voice translation-rule 30
rule 1 /^055/ /9055/
rule 2 /^04/ /904/
voice translation-profile PSTN-to-internal
translate calling 2
translate called 1
voice translation-profile callingpstn
translate calling 30
translate called 30
license udi pid xxxxxxxxxxxxxxxxxxxxxxx
license accept end user agreement
hw-module ism 0
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
interface Loopback0
ip address x.x.x.x
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface ISM0/0
ip unnumbered Loopback0
service-module ip address x.x.x.x x.x.x.x.x
!Application: CUE Running on ISM
service-module ip default-gateway x.x.x.x
interface GigabitEthernet0/1
ip address x.x.x.x.x
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip route x.x.x.x x.x.x.x.x
ip route x.x.x.x x.x.x.x.x ISM0/0
control-plane
voice-port 0/0/0:15
translation-profile incoming PSTN-to-internal
translation-profile outgoing callingpstn
voice-port 0/1/0
connection plar opx 2001
caller-id enable
voice-port 0/1/1
caller-id enable
mgcp profile default
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
name mobile
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer cor list user900-internal
member internal
member 900
dial-peer cor list user900-local
member internal
member local
member 900
dial-peer cor list user900-domestic
member internal
member local
member domestic
member 900
dial-peer cor list user900-international
member internal
member local
member domestic
member 900
dial-peer cor list user-900-internal
dial-peer cor list user-900-international
dial-peer cor list call-900-dom
dial-peer cor list mobile
member mobile
dial-peer voice 1 pots
description ** E1 PRI pots dial-peer **
destination-pattern 911
translate-outgoing calling 1
port 0/0/0:15
forward-digits 3
dial-peer voice 2 pots
destination-pattern 9911
port 0/0/0:15
forward-digits 3
dial-peer voice 4 pots
corlist outgoing call-domestic
destination-pattern 91T
port 0/0/0:15
dial-peer voice 3 pots
corlist outgoing call-local
destination-pattern 9T
port 0/0/0:15
dial-peer voice 5 pots
corlist outgoing call-international
destination-pattern 9011T
port 0/0/0:15
dial-peer voice 6 pots
corlist outgoing call-900
destination-pattern 91900.......
port 0/0/0:15
dial-peer voice 7 pots
destination-pattern 91976.......
port 0/0/0:15
forward-digits 11
dial-peer voice 8 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 9 pots
description ** FXO pots dial-peer **
port 0/0/0:15
forward-digits all
dial-peer voice 10 pots
port 0/0/0:15
forward-digits 3
dial-peer voice 11 pots
port 0/0/0:15
dial-peer voice 12 pots
port 0/0/0:15
dial-peer voice 13 pots
port 0/0/0:15
dial-peer voice 14 pots
port 0/0/0:15
dial-peer voice 15 pots
port 0/0/0:15
dial-peer voice 16 pots
port 0/0/0:15
forward-digits all
dial-peer voice 17 pots
port 0/0/0:15
forward-digits 3
dial-peer voice 18 pots
port 0/0/0:15
dial-peer voice 19 pots
port 0/0/0:15
dial-peer voice 20 pots
port 0/0/0:15
dial-peer voice 21 pots
port 0/0/0:15
dial-peer voice 22 pots
port 0/0/0:15
dial-peer voice 7000 voip
description VoiceMail
destination-pattern 7000
session protocol sipv2
session target ipv4:10.100.1.10
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 23 pots
destination-pattern 9050.......
port 0/0/0:15
forward-digits 10
dial-peer voice 24 pots
destination-pattern 9056.......
port 0/0/0:15
forward-digits 10
dial-peer voice 25 pots
destination-pattern 9055.......
port 0/0/0:15
forward-digits 10
dial-peer voice 26 pots
destination-pattern 9(0[1-46-9].......)
port 0/0/0:15
forward-digits 9
dial-peer voice 27 pots
preference 10
destination-pattern 9[1-57,9]......
port 0/0/0:15
forward-digits 7
sip-ua
gatekeeper
shutdown
telephony-service
tftp-server-credentials trustpoint IPTEL
no auto-reg-ephone
authentication credential Admin xxxxxx
max-ephones 40
max-dn 100
ip source-address x.x.x.x port xxx
calling-number initiator
timeouts interdigit 2
system messagexxxxxxxx
url services http://x.x.x.x/voiceview/common/login.do
url authentication http://x.x.x.x/CCMCIP/authenticate.asp
cnf-file location flash:
load 7942 sccp.23.sbn
time-zone 35
date-format dd-mm-yy
voicemail 7000
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000
web admin system name Admin secret 5 $1$HuvC$rDuCF.V9bjQ4IiGxKEY7H.
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
directory entry 1 9x name Carla
directory entry 2 9x name Dirk Drozd
directory entry 3 9x name Dirk Conference
directory entry 4 9x name Audrey Sequier
directory entry 5 9x name Salim ElFerkh
directory entry 6 9x name Natalie Khoury
directory entry 7 9x name Naji Atallah
directory entry 8 9x name Louay Dahmash
directory entry 9 9x name Wilfried Rilter
directory entry 10 9x name Ahmad Farshoukh
directory entry 11 9x name Hazem Khayat
directory entry 12 9x name Ganga Donga
directory entry 13 9x name Shrinandan Kulkarni
directory entry 14 9x name Rajanikanth Thouta
directory entry 15 9x name Mohamad Awad
directory entry 16 9x name Conference Room
directory entry 17 9x name Training Room
directory entry 18 9x name Pantry
directory entry 19 9x name Spare Desk 3
directory entry 20 9x name Spare Desk 4
directory entry 21 9x name Spare Desk 5
directory entry 22 9x name Spare Desk 7
directory entry 23 9x name Spare Desk 8
directory entry 24 9x name Technical Support
create cnf-files version-stamp 7960 Jul 24 2011 22:06:45
ephone-template 1
softkeys hold Resume Newcall Select Join
softkeys idle Redial Newcall ConfList RmLstC Cfwdall Join Pickup Login HLog Dnd
softkeys seized Endcall Redial Cfwdall Meetme Pickup Callback
softkeys alerting Endcall Callback
softkeys connected Hold Endcall Confrn Trnsfer Select Join ConfList RmLstC Park
ephone-dn 1 dual-line
number 703 secondary xxxxxxxxxxxx
label xxxxxxx
description xxxxxxxxxx
name xxxxxxxxxxxxxxxx
call-forward busy 7000
call-forward noan 7000 timeout 30
corlist incoming user900-international
ephone-dn 2 dual-line
number 704 secondary xxxxxxxxxxxxxx
label xxxxx
description xxxxxxxxxxxxxxxxx
name xxxxxxxxxxxx
ephone-dn 3 dual-line
number 705 secondary xxxxxxxxxx
label xxxxxxxxxxxx
description Natalie Khoury
name Natalie Khoury
ephone-dn 4 dual-line
number 706 secondary xxxxxxxxxxxx
label xxxxxxxxxxxx
name xxxxxxxxxxxxxx
ephone-dn 5 dual-line
number 707 secondary xxxxxxxxxxxxx
label xxxxxxxxxxxxxxx
ephone-dn 6 dual-line
number 710 secondary xxxxxxxxxxx
label xxxxxxxxxxxxxxxx
name xxxxxxxxxxxxxxxxx
ephone-dn 7 dual-line
number 711 secondary xxxxxxxxxxxxxxx
label xxxxxxxxxxx
ephone-dn 8 dual-line
number 712 secondary xxxxxxxxxxxxx
labelxxxxxxxxxxxxxx
ephone-dn 9 dual-line
number 713 secondary xxxxxxxxxxxxx
label xxxxxxxxxx
name xxxxxxxxxxxxxxxxxxxx
ephone-dn 10 dual-line
number 717 secondary xxxxxxxxxxxxx
name xxxxxxxxxxxxxx
ephone-dn 11 dual-line
number 718 secondary xxxxxxxxx
label xxxxxxxxxxxx
ephone-dn 12 dual-line
number 719 secondary xxxxxxxxxxxxx
label xxxxxxxxxxx
name xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ephone-dn 13 dual-line
number 722 secondary xxxxxxxxxxxxxx
name xxxxxxxxxxxxx
ephone-dn 14 dual-line
number 720 secondary xxxxxxx
label xxxxxxxxxxxxx
ephone-dn 15 dual-line
number 721 secondary xxxxxxxxx
label xxxxxxxxxxxx
ephone-dn 16 dual-line
number 702 secondary xxxxxxxxxxxxxx
label xxxxxxxxxxxx
name xxxxxxxxx
ephone-dn 17 dual-line
number 701 secondary xxxxxxxxxxxxxx
ephone-dn 18 dual-line
number 725 secondary xxxxxxxxxxx
ephone-dn 19 dual-line
number 726 secondary xxxxxxxxxx
label xxxxxxxxxxx
ephone-dn 20 dual-line
number 727 secondary xxxxxxxxxxxxx
label xxxxxxxxxxxxx
ephone-dn 21
number 728 secondary xxxxxxxxxxxxxxx
label xxxxxxxxxxxx
ephone-dn 22 dual-line
number 700 secondary xxxxxxxxxxxxx
ephone-dn 23 dual-line
number 777 secondary xxxxxxxxxxx
label xxxxxxxxxxxxxxxxxxxx
call-forward all 1
ephone-dn 51
number 400...
mwi on
ephone-dn 52
number 401...
mwi off
ephone 1
mac-address 1CAA.0710.31B8
ephone-template 1
username "xxxxxxxxxxxxx"
type 7942
button 1:1
ephone 2
mac-address 1CAA.0710.3327
ephone-template 1
username "xxxxxxxxxxxxxxxx"
type 7942
button 1:2
ephone 3
mac-address 1CAA.0710.3736
ephone-template 1
username "xxxxxxxxxxxxxxxxx"
type 7942
button 1:3
ephone 4
mac-address 1CAA.0710.3315
ephone-template 1
username "xxxxxxxxxxxxxx"
type 7942
button 1:4
ephone 5
mac-address 1CAA.0710.6250
ephone-template 1
username “xxxxxxxxxxxxx"
type 7942
button 1:5
ephone 6
mac-address 1CAA.0710.31A6
ephone-template 1
type 7942
button 1:6
ephone 7
mac-address 1CAA.0710.34DA
ephone-template 1
username "xxxxxxxxxxx"
type 7942
button 1:7
ephone 8
mac-address 1CAA.0710.3328
ephone-template 1
type 7942
button 1:8
ephone 9
mac-address 1CAA.0710.352B
ephone-template 1
type 7942
button 1:9
ephone 10
mac-address 1CAA.0710.3388
ephone-template 1
username "xxxxxxxxxxxxxxxxxx"
type 7942
button 1:10
ephone 11
mac-address 1CAA.0710.36C9
ephone-template 1
username "xxxxxxxxxxxxxxxxxxxxxxx"
type 7942
button 1:11
ephone 12
mac-address 1CAA.0710.2F83
ephone-template 1
type 7942
button 1:12
ephone 13
mac-address 1CAA.0710.3266
ephone-template 1
type 7942
button 1:13
ephone 14
mac-address 0004.F2ED.3050
ephone-template 1
username "xxxxxxxxxxxxxxx"
type 7942
button 1:14
ephone 15
mac-address 1CAA.0710.34B8
ephone-template 1
type 7942
button 1:15
ephone 16
mac-address 0004.F2ED.1824
ephone-template 1
username "xxxxxxxxxxxxxxxxxxx"
type 7942
button 1:16
ephone 17
mac-address 1CAA.0710.330F
ephone-template 1
type 7942
button 1:17
ephone 18
mac-address 1CAA.0710.3414
ephone-template 1
username "xxxxxxxxxxxx"
type 7942
button 1:18
ephone 19
mac-address 1CAA.0710.32B4
ephone-template 1
type 7942
button 1:19
ephone 20
mac-address 1CAA.0710.3385
ephone-template 1
username "xxxxxxxxxx"
type 7942
button 1:20
ephone 21
mac-address 1CAA.0710.33A4
ephone-template 1
username ”xxxxxxxxxxxx"
type 7942
button 1:21
ephone 22
mac-address 1CAA.0710.35B9
ephone-template 1
type 7942
button 1:22
ephone 23
username "TechnicalSupportHotline"
line con 0
line aux 0
line 131
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
ntp source GigabitEthernet0/1
ntp master 10
ntp update-calendar
end
CME#
telephony-service
create cnf-files
HTH,
Justin
Dear Sir,
I have alreday attached 2 snap shots like i am getting this error in all phone but my phones normally boots and in between for 1 sec i recieved an error which is alreday attached with my post and then my phone registered properly.
I will try this and then check.
Dear Sir,
I had tried now its working thanks alot for your time and concern in this matter
