Outgoing calls through h323 gateway fails
Hello!
Please help..I`m trying to set up a new CUCM 8.6.1(a). All is well, but it`s impossible to configure pass calls through h323-gateway. Appropriate route-patterns and CSS are configured. Incoming calls over this h323-trunk successfully come to call-manager, but an outgoing call I hear the tube short beeps. I note that if I make the inter-cluster trunk, everything works in both directions.
P.S. On my existing CUCM 7.1.5 this problem did not exist.
24 Replies 24
acampbell
Can you provide the router config and explain the number being dialled
Alex
Regards, Alex. Please rate useful posts.
Yes, certainly. Once again I will specify that with this router successfully works my existing CUCM 7.1.5
For example I try to dial number 94571919, which matching with a "dial-peer voice 106 pots"
version 15.1
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname M69-KFB-VOICE
boot-start-marker
boot system flash:c2951-universalk9_npe-mz.SPA.151-3.T.bin
boot-end-marker
card type e1 0 3
logging buffered 51200 informational
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
aaa session-id common
clock timezone MSK 4 0
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name *.ru
ip name-server 8.8.8.8
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  emptycapability
  h225 signal overlap
  h225 connect-passthru
  h245 passthru tcsnonstd-passthru
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice translation-rule 1
rule 1 /44.../ /8124571919/ type any subscriber plan any isdn
rule 2 /41.../ /8126110000/ type any subscriber plan any isdn
rule 3 /.*/ /8124571919/
voice translation-rule 10
rule 1 reject /9287473224/
voice translation-rule 30
rule 1 /.*/ /44700/
voice translation-rule 50
rule 1 /.*/ /99051000127991/
voice translation-profile Gorod
translate calling 1
voice translation-profile Incoming-Call-Block
translate calling 10
voice translation-profile SKYPE
translate calling 50
voice translation-profile incoming_from_SIP_provider
translate called 30
fax receive called-subscriber $d$
mta send server 10.105.4.40 port 25
mta send subject CISCO FAX SERVER
mta send with-subject both
mta send filename fax.tif date
mta send postmaster *
mta send mail-from hostname *.ru
mta send mail-from username robot
application
service tkbmenu flash:vxml-ivr/TKB2.vxml
service fax flash:app_fax_detect.2.1.2.3.tcl
  param mode listen-first
  param prompt flash:/Prompts/en/en_default_fax.au
service KITFinance flash:kit-ivr/KFB-RU.vxml
vxml audioerror
vxml version 2.0
license udi pid CISCO2951/K9 sn FCZ143371ND
hw-module pvdm 0/0
hw-module pvdm 0/1
archive
log config
  logging enable
  notify syslog contenttype plaintext
  hidekeys
redundancy
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/3/1
shutdown
framing NO-CRC4
ip ssh version 2
interface Loopback0
ip address 10.56.253.2 255.255.255.0
interface GigabitEthernet0/0
description ### MNG ###
ip address 10.56.0.50 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description ### DATA ###
ip address 10.59.1.5 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.59.1.5
interface GigabitEthernet0/2
description ### INET ###
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/3/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http secure-port 4434
ip route 0.0.0.0 0.0.0.0 10.56.0.1
ip access-list standard SNMP-Access
permit 10.58.10.58
permit 10.57.5.21
permit 10.57.5.25
permit 10.105.4.10
permit 10.105.1.20
logging trap debugging
logging source-interface GigabitEthernet0/0
logging 10.57.5.21
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0
cptone RU
description TEST
voice-port 0/0/1
cptone RU
voice-port 0/0/2
cptone RU
voice-port 0/0/3
cptone RU
voice-port 0/3/0:15
voice-port 0/1/0
cptone RU
voice-port 0/1/1
cptone RU
voice-port 0/1/2
cptone RU
voice-port 0/1/3
cptone RU
description ### DCF_FAX ###
voice-port 0/3/1:15
voice-port 0/2/0
cptone RU
voice-port 0/2/1
cptone RU
mgcp profile default
dial-peer voice 100 pots
description Telephony-Operator
translation-profile outgoing Gorod
preference 1
destination-pattern 9810T
direct-inward-dial
port 0/3/0:15
prefix 810
no sip-register
dial-peer voice 102 pots
preference 1
destination-pattern 98[^1].........
direct-inward-dial
port 0/3/0:15
prefix 8
no sip-register
dial-peer voice 104 pots
preference 1
destination-pattern 90T
direct-inward-dial
port 0/3/0:15
prefix 0
no sip-register
call-block translation-profile incoming Incoming-Call-Block
call-block disconnect-cause incoming call-reject
preference 1
destination-pattern 9[^8]......
direct-inward-dial
port 0/3/0:15
no sip-register
dial-peer voice 1100 voip
description ### Internal_numbers ###
destination-pattern 4....
session target ipv4:10.97.4.4
codec g711ulaw
no vad
dial-peer voice 1001 pots
service tkbmenu
incoming called-number 6110000
direct-inward-dial
dial-peer voice 1101 voip
description ### Redirect to Msk Willstream ###
destination-pattern 1....
codec g711ulaw
no vad
dial-peer voice 1002 pots
description TEST
destination-pattern 49998
port 0/0/0
no sip-register
dial-peer voice 1003 pots
destination-pattern 41233
port 0/1/3
no sip-register
dial-peer voice 1004 pots
description ### 3323990_44950 ###
destination-pattern 44950
port 0/0/0
no sip-register
dial-peer voice 1005 pots
description ### 3323260_44350 ###
destination-pattern 44350
port 0/0/1
no sip-register
dial-peer voice 1006 pots
description ### 3348823_44355 ###
destination-pattern 44355
port 0/0/2
no sip-register
dial-peer voice 1007 pots
description ### 3323266_44952 ###
destination-pattern 44952
port 0/0/3
no sip-register
dial-peer voice 1008 pots
description ### 3323291_44352 ###
destination-pattern 44352
port 0/1/0
no sip-register
dial-peer voice 1102 voip
description ### Avaya ###
destination-pattern [1-3,5-8]....
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1009 pots
description ### ISDN-IVR ###
service kitfinance
incoming called-number 4571919
direct-inward-dial
no sip-register
dial-peer voice 1111 voip
description ### INCOMING_SIP ###
translation-profile incoming SKYPE
huntstop
answer-address 99051000127991
redirect ip2ip
session protocol sipv2
incoming called-number 99051000127991
voice-class codec 1
no voice-class sip session refresh
no vad
dial-peer voice 1010 pots
description ### FAX-DEPOSITARIUM ###
destination-pattern 44951
port 0/1/1
dial-peer voice 1103 voip
description ### Avaya_Backup ###
session target ipv4:10.97.4.5
codec g711ulaw
no vad
dial-peer voice 1200 pots
description ### ISDN-IVR_8-800 ###
service kitfinance
incoming called-number 3323529
direct-inward-dial
no sip-register
dial-peer voice 1011 pots
description ### FAX-SERVER ###
destination-pattern 44999
port 0/2/0
no sip-register
dial-peer voice 110 pots
service fax
incoming called-number 3323260
direct-inward-dial
forward-digits all
dial-peer voice 111 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 3323260
information-type fax
session target mailto: *clients@brokerkf.ru
dial-peer voice 101 pots
preference 2
direct-inward-dial
port 0/3/1:15
prefix 810
no sip-register
dial-peer voice 103 pots
preference 2
direct-inward-dial
port 0/3/1:15
prefix 8
no sip-register
dial-peer voice 105 pots
preference 2
direct-inward-dial
port 0/3/1:15
prefix 0
no sip-register
dial-peer voice 107 pots
preference 2
direct-inward-dial
port 0/3/1:15
no sip-register
dial-peer voice 1105 voip
description ### Lync ###
destination-pattern 33...
codec g711ulaw
no vad
dial-peer voice 1020 pots
description ### IT FAX ###
destination-pattern 44710
port 0/1/2
dial-peer voice 1104 voip
destination-pattern 10.
session target ipv4:10.57.4.10
codec g711ulaw
no vad
num-exp 3261318 41237
num-exp 3261349 44731
num-exp 3261351 44734
num-exp 3323297 41243
num-exp 3320032 44934
num-exp 3323296 44020
num-exp 7024101 44560
num-exp 7024142 44922
num-exp 3261315 44896
num-exp 3323295 41233
num-exp 3323266 44952
num-exp 3348823 44355
num-exp 99051000127991 41235
num-exp 4571999 44503
num-exp 3323291 44352
num-exp 3323290 44950
num-exp 2400101 48533
num-exp 3268890 44700
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.59.1.5 port 2000
max-ephones 200
max-dn 200
system message primary Backup_Telephony!
system message secondary Backup_Telephony!
transfer-pattern .T
line con 0
line aux 0
line vty 0 4
exec-timeout 100 0
logging synchronous
transport input ssh
line vty 5 15
exec-timeout 100 0
logging synchronous
transport input ssh
scheduler allocate 20000 1000
ntp server 10.96.0.1 source GigabitEthernet0/0
end
Just to test can you add these lines to the config
voice service voip
no ip address trusted authenticate
Alex
Has tried. Doesn't work.
As you said dial peer 106 POTS should be matched.
What about a VOIP dial peer from the new CUCM which H323 VOIP dial peer matches the CUCM
Alex
torsten.brink
Have you checked call routing on CUCM and can you confirm that h.323 messages are received on GW, when doing outbound calls?
Cheers
Torsten
Hi.
Can you send us the output of a debug voip dialpeer inout and a debug isdn q931 during an outgoing call?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
I can`t send these debugs because on a router doesn't come any traffic from my CUCM 8.6.1.
On the CUCM all necessary rout-patterns are adjusted. I repeat that if I make inter-cluster trunk instead of h323-gateway then all works perfectly.
May be its a bug in the CUCM 8.6.1??
Unfortunately, I don't have any appropriate smartnets to open a case in TAC
Hi.
Just a check...
Can you try to put your H323 gateway in a route group than in a route list and use this RL for route patterns.
Let me know.
Carlo
Carlo,
I already tried it to do - doesn't help...
May be it`s necessary somewhere in CUCM-services something check/uncheck..I`m in confusion..
Hi.
Have you tried to check MTP Required falg on H323 Gateway config?
Carlo
Carlo,
Yes MTP flag is checked in gateway config
Hi Arnela
don`t direct attention on my IOS-gateway. In parallel with the problem CUCM 8.6.1 I have the CUCM 7.1.5 with identical settings, which works fine.I can use various devices on another side of my 323-trunk and outgoing calls won't work.
Hi all!
I see the trace files in my CUCM 8.6.1 and see the next one message (when I call from CUCM to h323 gateway):
(88) Incompatible destination
The cause could be one of the following occurrences:
•     The number being dialed is not capable of the type of call.
You are calling a restricted line in unrestricted mode.
You are calling a POTS phone using unrestricted mode.
What this mean and where I should search my problem??
