IP Telephony and Phones
Bookmark
Subscribe
Labels
Hi guys. I have calls running between 2 voip systems trough sip and i have about 7 hop between them (2 mpls and the rest of them internal between routers (fiber connection) ) .When I see logs I see too big jitter from 1000-4000 ms , packet loss 15%-4...
Is there any workaround or solution available to this problem? Is it possible to use least cost routing for Site A and Site B number so it will local call for us from Site C .Site A number range is +63,Site B Number range is +61 and Site C is +91 but...
Dear Team ,ATA 190 was one mac rejected and one unregisterd. I upgraded cmterm-ata190.1-1-0-006.cop.sgn to cmterm-ata190-qed.1-1-1-001.cop.sgn + cmterm-ata190-qed.1-1-1-001.cop.sgn and rebooted CM. ATA completely disappear from CUCM once i delete fro...
Hi community,currently i´m trying to set up a CUCM/CUPS (10.5) BE6000 Cluster, thought all is working fine, now i finally try to "attach" the Jabber-Client (10.5) to my deskphone, all should be configured correctly.Since i need to use CTI for control...
Hello,i want to use a CUBE HSRP configuration in my CUCM environment.Every time when my CUCM send a SIP request or invite to the HSRP IP, my CUBE use the physical IP in the answer packet.(see attached File).I tried to bind HSRP IP to the incoming dia...
Sascha K. by Level 1
  • 3674 Views
  • 8 replies
