07-12-2016 09:01 AM - edited 03-17-2019 07:31 AM
Hello everyone,
I have a question about selection of outgoing dial-peer and strange behavior. This is my current config(CME=8.6):
R1#sh dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE
20001 pots up up 30022$ 0 50/0/1
20002 pots up up 3002$ 0 50/0/2
5 voip up up 2T 0 syst ipv4:192.168.2.2
15 voip up up 2... 0 syst ipv4:192.168.2.2
R1#
dial-peer voice 5 voip
destination-pattern 2T
session protocol sipv2
session target ipv4:192.168.2.2
dial-peer voice 15 voip
destination-pattern 2...
When I am calling 200123424 (onhoook&dial or offhook), but it's cutting to 2001 and NO IDT.
Both dial-peers are used from time to time and it cuts to 2001 even with dial-peer 5.
R1#show voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x3 11EE 0x31DB8858 50/0/2.0 2002 g729r8 20002/5
1 active call found
0x9 1200 0x31DB8858 50/0/2.0 2001 g729r8 20002/15
1 active call found
When I removed dial-peer 15, I was able to call 200123424 and it was IDT. What is the logic here? How dial-peer 15 can influence on dial-peer 5 :)?
Thank you in advance.
07-12-2016 12:49 PM
This is the order of preference for dial-peer hunt 0 which you have.Longest match in phone number, explicit preference, random selection.
In this case as when you dial 2001XXXXX soon as 2001 is matched against 2... pattern it is taking that dial-peer.
If you dial only 2001 then both dial-peer have a match and it is random selection.thanks
07-13-2016 02:45 AM
Good day Deepak,
thank you for you reply.
<< when you dial 2001XXXXX soon as 2001 is matched against 2... pattern it is taking that dial-peer.
I would agree with you, if I had two patterns: 2... and 2........ In my case I have one pattern: 2T, so I expect to see IDT after each digit. But I have immediately dialing to 2001 after 4 digit.
<<If you dial only 2001 then both dial-peer have a match and it is random selection
In my case I see random selection in case of dialing 2001XXXXX (onhook,dial) as well.
Anyway, thank you for your comments.
Dmitry
07-12-2016 01:46 PM
Try 2...$
07-13-2016 02:48 AM
Good day Jaime, thank you for your message.
Let me give you more information.
R1#sh run | sec dial-peer
destination-pattern 2...$
R1#
Now, any time I call to 2001XXXX, it used only dial-peer 15 and terminate call on dn=2001:
Jul 13 06:59:17.139: ephone-2[1/2][SEP54781AE10097]:OFFHOOK with called party 20015555
Jul 13 06:59:17.139: ephone-2[1/2][SEP54781AE10097]:Fake redial to 20015555
Jul 13 06:59:17.139: ephone-2[1/2][SEP54781AE10097]:Normal ReDial press 20015555 line 1
I don't understand the logic in this case of overlapping.
It has to use dial-peer 5 for enblock, and in case of dialling in off-hook mode - IDT.
But when I have more specific dial-peer 15, it is just ignore another dial-peer 5 with T-symbol.
R1#debug voice dialpeer inout
voip dialpeer inout debugging is on
R1#
Jul 13 06:51:37.131: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3002, Called Number=, Voice-Interface=0x2C11DC3C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20002
Jul 13 06:51:37.131: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Jul 13 06:51:37.547: //-1/142000AB8056/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=2
Result=Partial Matches(1) after DP_MATCH_DEST
Jul 13 06:51:37.547: //-1/142000AB8056/DPM/dpMatchSafModulePlugin:
dialstring=2, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Jul 13 06:51:37.547: //-1/142000AB8056/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
Jul 13 06:51:37.747: //-1/142000AB8056/DPM/dpMatchPeersCore:
Calling Number=, Called Number=20, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=20
Jul 13 06:51:37.747: //-1/142000AB8056/DPM/dpMatchSafModulePlugin:
dialstring=20, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Jul 13 06:51:37.747: //-1/142000AB8056/DPM/dpMatchPeersMoreArg:
Jul 13 06:51:37.947: //-1/142000AB8056/DPM/dpMatchPeersCore:
Calling Number=, Called Number=200, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=200
Jul 13 06:51:37.947: //-1/142000AB8056/DPM/dpMatchSafModulePlugin:
dialstring=200, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Jul 13 06:51:37.947: //-1/142000AB8056/DPM/dpMatchPeersMoreArg:
Jul 13 06:51:38.147: //-1/142000AB8056/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2001, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=2001
Result=Success(0) after DP_MATCH_DEST
Jul 13 06:51:38.147: //-1/142000AB8056/DPM/dpMatchSafModulePlugin:
dialstring=2001, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Jul 13 06:51:38.147: //-1/142000AB8056/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=15
dialstring=2001, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Jul 13 06:51:38.147: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=2001, Called Number=2001, Peer Info Type=DIALPEER_INFO_SPEECH
Jul 13 06:51:38.147: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 13 06:51:38.147: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Jul 13 06:51:38.147: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Calling Number=2001, Called Number=, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=15
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
dialstring=2001, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Jul 13 06:51:38.151: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 13 06:51:38.151: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 13 06:51:38.151: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Jul 13 06:51:38.283: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=3002, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=3002
Jul 13 06:51:38.283: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 13 06:51:38.283: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=20002
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Jul 13 06:51:38.283: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
Jul 13 06:51:38.859: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 13 06:51:38.859: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 13 06:51:38.859: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=15
2: Dial-peer Tag=5
R1#
Thank you for your message.
Dmitry
