Paging Multicast
kashif2401
We have a new setup , where we have  :-
1. Informacast Paging Server in Vlan 14  of Core Switch-3850  ( Paging Server IP : 10.10.14.5)
    ------ Server Vlan SVI IP Address  -  10.10.14.1 (Core Switch 3850 )
2. IP Phones in Vlan 11 of Access Switches ( 3850 Access Switches Connected to Core Switch 3850 by TRUNK )
    ------  Voice Vlan SVI IP address  - 10.10.11.1 ( on Core Switch 3850 )
Need to configure Multicasting from Paging Server(Vlan 14)  to IP Phones (Vlan 11) . Can anyone give a simple and clear configuration for this ?
8 Replies 8
balaji.bandi
actually i was having issue in this one only, when i dig more into this, my core switch is having lanbase license which doesnt support multicast and pim.
Now my question is do i have to take license for ipservice for all the access switches as well or only for core switch?
You will need the ip services license.
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
You can enable multicast as follows:
ip multicast-routing
Interface vlan 14
   ip pim sparse-mode
interface vlan 11
   ip pim sparse-mode
interface loopback 1
 ip address 192.168.1.1 255.255.255.255
ip pim rp-address 192.168.1.1
John
this is perfect solution but now my main concern is do i have to take that license for all the access switches in the network or the license for core switch will be enough?
You just need license for the layer 3 devices, in your case, just the core switch.
John
Great! thanks for all the help, really appreciate it.
