01-04-2016 01:56 PM - edited 03-17-2019 05:23 AM
Dear All,
Please Help me
I seek a method to reset the password of a VG310 Gateway.
On the site cisco I have found no
01-05-2016 01:10 AM
it should be the same as any router , send a break at boot, after the memoy count is finished.
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/12818-61.html
01-05-2016 02:07 AM
You can perform the same step as stated in the below link for 2XXX router. This is for 2800 but is exactly the same in a VG310. Certainly you will not find any such document explicitly for VG3XX etc
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/22188-pswdrec-2600.html
Please keep in mind that in order to do the password recovery we will need to have console
access and the device has to be reloaded at least twice.
Br,
Nadeem Ahmed
PS: Please rate all usefull post.
