01-31-2011 05:11 AM - edited 03-16-2019 03:10 AM
Hello buddy
I'm problem
In a customer. When I use UPC 7.x the calls between site (g729 works fine). But when I use UPC 8.0.171.15962 (CSF) the calls using g729 (softphone mode) not works. I need change de codec of region to g711.
Somebody knows if the Personal 8.0.171.15962 have a problem with g729?
The xcode is correct and, again, the UPC 7 works fine with all codec.
Peterson
01-31-2011 05:49 AM
I found the problem.... but not the solution.
The personal 8 (CSF) have a problem with use the SIP TRUNK, example
We have a cucm and pbx using SIP TRUNK
When upc 7 call the phones of pbx in g729, the calls works
When upc 8 (csf) call the phons of pbx in g729, the calls not works (work just in g711).
Now is find the solution
04-19-2012 09:13 AM
Hi Paul
No buddy, I not found the solution....you tried upgrade de CSF....I think is a problem between sip x h323 negation with codec. You trunk with GK use MTP?
Best Regards
Peterson
04-19-2012 01:55 PM
So.... CSF doesnt support G729b apparantly
Yo can use
G711a or G771u
G722
G729a or G729ab
Grrrrrrrrrrrrrrrrrrrr
04-19-2012 01:55 PM
or
iLBC
ISAC
04-19-2012 01:56 PM
p.s. sorry that was me above. Didnt realise I was in using our group account
Paul Everson
