Hello buddy
I'm problem
In a customer. When I use UPC 7.x the calls between site (g729 works fine). But when I use UPC 8.0.171.15962 (CSF) the calls using g729 (softphone mode) not works. I need change de codec of region to g711.
Somebody knows if the Personal 8.0.171.15962 have a problem with g729?
The xcode is correct and, again, the UPC 7 works fine with all codec.
Peterson
I found the problem.... but not the solution.
The personal 8 (CSF) have a problem with use the SIP TRUNK, example
We have a cucm and pbx using SIP TRUNK
When upc 7 call the phones of pbx in g729, the calls works
When upc 8 (csf) call the phons of pbx in g729, the calls not works (work just in g711).
Now is find the solution
Hi Peterson
Did you find the fix?
We have a similar issue where we can't send g729 down a h323 gatekeeper trunk from csf 8 but can from deskphones or IP communicator devices (on the same IP address! )
Cheers
Hi Paul
No buddy, I not found the solution....you tried upgrade de CSF....I think is a problem between sip x h323 negation with codec. You trunk with GK use MTP?
Best Regards
Peterson
Hi Peterson,
No the H323 gatekeeper trunks we are using do not use a MTP.
I have logged a call with Cisco TAC so lets see what they have to say!!
Cheers,
So.... CSF doesnt support G729b apparantly
Yo can use
G711a or G771u
G722
G729a or G729ab
Grrrrrrrrrrrrrrrrrrrr
or
iLBC
ISAC
p.s. sorry that was me above. Didnt realise I was in using our group account
Paul Everson
