Personal Contact
pascal.boucher
Hi, does anybody know if there is a maximum number of personal contact that a user can create un CUCM 9.1?
Tshepo
Having mentioned CUCM 9.1, I'd assume you have a jabber client installed?
Best option would be to add most of your personal contacts using your jabber client as it has a much broader in terms of the amount of entries one can have.
