Personal Directory phone edit option not available
my CUCM running with System version: 10.5.2, and we are using CISCO-7962 both SIP and SCCP
this phones load id is "SCCP42.9-4-2-1S
phone wrking fine, but when i am trying to edit contact from personal directory , there is no option to edit phone no.
it means, I can edit names but no option for edit Number.
thanku in advance
If you look at your softkeys, you should find one named "phones", where you can edit contact numbers.
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo Poggiarelli
I can't see that option..
i can edit names , but there is no option to edit phone no. ("phone" soft key not showing)
Do you have another phone type to test it?
Can you please post a couple of screenshot of the 7962 display while using Personal directory?
Carlo
Hi.
Sorry but you are hitting bug id: CSCut45211
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCut45211/?referring_site=bugquickviewredir
As you can see in bug description, you need to perform an upgrade to fix this issue.
Sorry again
Carlo
