ā07-17-2017 12:03 AM - edited ā03-17-2019 10:48 AM
We set up a Hunt Pilot and configure the "Forward Hunt No Answer" & "Forward Hunt Busy" to one AA on our CUE. Then I use a test phone to dial the hunt pilot number and let all members wait until the call is forwarded to the AA. But I could not see any record in the Hunt Pilot Detail CDR report, in my understanding, there should be a record with "FONA" set to "Y", right? Same problem for FOB.
And I have one more question: in the line group, we set the "Distribution Algorithm" to "Longest Idle Time", so the members will ring one by one if they not answer, but there's only one record in the Hunt Pilot Detail CDR report with the member who finally answers or abandons, is it possible to also have the records of the members who did not answer before?
We are running CUCM 8.5.1
Thanks.
Savi
Solved! Go to Solution.
ā07-17-2017 12:19 AM
By default, Final Called Party Number will show the DN of last member who answer/abandon the call. It is not possible to show the records of members who were presented with the call earlier. For FONA and FOB fields showing "N", did the call successfully go to AA on CME or not. Is the count for FONA and FOB increasing in Hunt Pilot Summary report or not.
Deepak
ā07-17-2017 02:57 AM
Most probably you are hitting below defect:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCto77083/?reffering_site=dumpcr
Deepak
Deepak
ā07-17-2017 12:26 AM
Hello Deepak,
Thanks for your reply.
Yes, the call successfully goes to the AA. But there's no record in both the detail & summary report.
Savi
Deepak
ā07-20-2017 11:01 PM
Hello Deepak,
I tried with CUCM version 11.0 today and FONA & FOB work well, so the BUG you find should be the reason. Thanks for your information.
Savi
ā07-21-2017 01:55 AM
Glad that I was able to help Savi and thanks for marking the Correct Answer.
Deepak
