Phantom Overnight Calls
jshdcooper
I've got a peculiar issue. A client is reporting that their phone system is calling random people at all hours of the night. I ran a debug isdn q931, and sure enough, found where those numbers are being called. There is some strange output from the debug, I was hoping someone here might be able to help shed some light on.
Here is some pertinent debug information. Interesting, those H323 debugs come in with an incorrect timestamp, and I don't see them ever during business hours when there are no inappropriate calls reported. We do not have an H323  gateway.
059129: Jan 30 02:07:50.240: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x9168
        Progress Ind i = 0x8188 - In-band info or appropriate now available
059130: Jan 30 07:08:04.316: %VOICE_IEC-3-GW: H323: Internal Error (Socket error): IEC=1.1.186.5.7.6 on callID 4530        7 GUID=3ADF16EA46C31D263BC161799CEC4C2C
059131: Jan 30 02:08:04.340: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x1168
        Cause i = 0x80A6 - Network out of order
059132: Jan 30 02:08:04.352: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x9168
        Cause i = 0x82E4 - Invalid information element contents
059133: Jan 30 02:08:04.352: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x1168
059134: Jan 30 02:14:44.994: ISDN Se0/0/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x1 may be overriden;        sw-type 13
059135: Jan 30 02:14:44.994: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x1169 callID = 0x90EA switch = primary        -ni interface = User
059136: Jan 30 02:14:44.994: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x1169
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98395
                Exclusive, Channel 21
        Called Party Number i = 0xC1, 'xxxxxxx'
                Plan:ISDN, Type:Subscriber(local)
059137: Jan 30 02:14:45.042: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9169
059138: Jan 30 02:14:48.086: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x9169
059139: Jan 30 07:15:14.970: %VOICE_IEC-3-GW: H323: Internal Error (Socket error): IEC=1.1.186.5.7.6 on callID 4530        9 GUID=FED5663502C711A11DE9F9581075D0FF
059140: Jan 30 02:15:14.986: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x1169
059141: Jan 30 02:15:14.998: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x9169
059142: Jan 30 02:15:14.998: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x1169
deepaul
Is this a contact center environment ?
I would say that you check if they have any Callback option or outbound dialing mechanism  in the system.
regards,
Deepu
Could You be pleased to describe VOIP system configuration?
It is not a contact center. It is a fairly straight forward CME environment. Using CUE for auto attendant and exchange for voicemail.
I set up a translation for one of the numbers being reportedly phantom called to redirect to my cell and got a call this morning at 3am.
The translation pattern is applied to
dial-peer voice 3 pots
 description ** T1 PRI pots dial-peer **
 translation-profile outgoing outbound_caller_id
 preference 3
 destination-pattern 9[2-9]......
 port 0/0/0:23
