09-22-2021 09:11 AM
Hi everyone,
I have a customer running CME version 12 and only one Cisco Phone 7841 can't make external calls. Any other voice register DN using the same phone model works fine for internal and external.
I collected the output of "debug ccsip all" and could see the error as follow. I've attached the whole collected output.
I already did remove the entire DN e Pool configuration e reentered it again. Also, we've tried with another device model (3905) without success.
Does anyone know what else we can check or try?
021586: *Sep 22 12:12:37.005: //820909/32D74FCE8819/SIP/Info/info/16416/sipSPIClearKPMLClientContext: Cleared KPML Client Info Context
021587: *Sep 22 12:12:37.005: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
021588: *Sep 22 12:12:37.005: //820909/32D74FCE8819/SIP/State/sipSPIChangeState: 0x3882AC8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
021589: *Sep 22 12:12:37.005: //820909/32D74FCE8819/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x3882AC8
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 6965 (the only one DN with this simptom)
Called Number : 0 (customer dialed external number was 0976749826)
Source IP Address (Sig
Destn SIP Req Addr:Port : 172.16.7.78:5060
Destn SIP Resp Addr:Port : 172.16.7.78:5060
Destination Name : 172.16.7.78
021590: *Sep 22 12:12:37.005: //820909/32D74FCE8819/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711ulaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 172.16.7.1
Source IP Port (Media): 30168
Destn IP Address (Media): 172.16.7.78
Destn IP Port (Media): 22018
Orig Destn IP Address:Port (Media): [ - ]:0
021591: *Sep 22 12:12:37.005: //820909/32D74FCE8819/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 487
021592: *Sep 22 12:12:37.005: //820909/32D74FCE8819/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id C86AD
021593: *Sep 22 12:12:37.005: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[754394] removed.
09-22-2021 09:16 AM
