IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5934 Views
  • 14 replies
Is there a way to monitor (listen) in on active non-agent calls?  The customer will be using a combination of Cisco 78XX, 88XX and Jabber devices and wants the ability for managers to actively listen in to on-going calls.  These are non-contact devic...
dpaquet by Level 1
  • 4160 Views
  • 5 replies
I'm attempting to create a VPN for a Cisco 7962. The phone says VPN Authentication Failed when attempting to connect. I downloaded console logs and I think this is relevant information bolded: 918: NOT 02:57:09.836553 VPNC: cert_vfy_cb: depth:1 of 1,...
Morning all. We have a GSM gateway which is becoming cheaper to make calls through right now, as as test we want to set up a department to push all calls out of this gateway as a test. I understand how to route calls out of the gateway via route patt...
Chetty by Level 1
  • 792 Views
  • 5 replies
