Cisco 6945 on CUCM 12.5
kapil.atrish
Level 4
Level 4
Hi all,
Does anybody have Cisco 6945 phone running on CUCM 12.5 and working fine?
I see 6945 as eol but not deprecated yet.
tx
Kapil
The 6945 phone is in the list of phones that you can add to CUCM 12.5 (I'm just looked at that in my lab to be sure.) With that, since it is natively supported by CUCM 12.5 it should work without a problem.
Are you experiencing an issue or just asking?
Maren
As @Maren Mahoney mentioned, 6945's are supported on CUCM 12.5. EOL doesn't mean that the device is no more supported by CUCM.
Since its not a deprecated phone model its works with Your CUCM.
Are you facing any issue with the phones ?
Response Signature
Hi Kapil,
you can check the link and attachment captured from same link
Compatibility Matrix for Cisco Unified Communications Manager and the IM and Presence Service, Release 12.5(X) - Cisco
regds,
aman
