12-07-2015 07:34 AM - edited 03-17-2019 05:08 AM
Good Morning,
I've been trying to register a 8811 IP Phone to a 8.6.2 CUCM. I have installed the Device Pack 8.6.2.26169-1, IP phone Firmware 11-0-1-11.k3 and still getting the message "Telephony Service Unavailable"; I have tried with manual and auto-registry options and nothing.
I checked the security options at the phone and they are at default options.
Have anyone resolve an issue like this? Please help me to add this device to the CUCM.
Thanks.
Solved! Go to Solution.
12-07-2015 08:14 AM
If you installed the DevPack to add support for that model, did you perform a cluster reboot after that??
12-07-2015 08:14 AM
12-07-2015 08:23 AM
No I didn't reboot the Cluster after adding the DevPack. I will an let you know.
12-07-2015 08:20 AM
Hi there,
In addition to the good tips from my friend Java (+5) Maybe you are hitting this bug;
12-07-2015 08:35 AM
Hello, I have verified at the Phone Buttom Template and it only has 2 line options and 3 speed dial options.
I have verified the IP address and I can´t see the IP address the telephone gets on the CUCM.
12-08-2015 01:49 PM
Thanks a lot Jaime, after rebooting the device registered without any problem,
12-08-2015 03:20 PM
Glad to hear that, FYI, the README for the DevPack explains you should have done that right after the installation, you should ALWAYS read the relevant documentation when installing something on your server.
