Phone button compatibility in CUCM 10.5
Flexcom99
Hi folks,
I try to understand something about the phone button template in 10.5.
It seems that we can now select a phone button template of a 8945 model for instance to apply on a 7962 model (screenshot1).
But, you can't do this for all kind of phones (69XX series or 99XX series as I noticed on screenshot2).
How do you know which models can support the multi selection ? Tried to find out but no luck so far.
Any idea ?
Fabian
2 Accepted Solutions
Manish Gogna
Hi Fabian,
It looks related to the Extension mobility equivalency and Size Safe features as described here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmfeat/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100_chapter_011000.html#CUCM_RF_EDCB3C30_00
Manish
Amit Sharawat
Hi Fabian,
Only the following Cisco IP phone models  supports multi-selection. Rest all other phone models have specific their Phone button template.
Cisco 7906
Cisco 7941
Cisco 7941G-GE
Cisco 7942
Cisco 7945
Cisco 7961
Cisco 7961G-GE
Cisco 7962
Cisco 7965
Cisco 7970
Cisco 7971
Cisco 7975
Cisco IP Communicator
That's primarily because all of the above phones are inter-operable with EM. If the Device profile is created with any of the above models, then user can login with EM on any of the phone models specified above and their will not be any compatibility issues.
For rest of the phone models, If somebody wants use EM with a specific phone model, then we have to create the device profile for the user using same Phone model.
I hope this helps.
~Amit
Manish Gogna
Hi Fabian,
Manish
Thanks Manish, it helped a lot.
Amit Sharawat
Hi Fabian,
Cisco 7906
Cisco 7941
Cisco 7941G-GE
Cisco 7942
Cisco 7945
Cisco 7961
Cisco 7961G-GE
Cisco 7962
Cisco 7965
Cisco 7970
Cisco 7971
Cisco 7975
I hope this helps.
~Amit
