01-06-2016 02:03 AM - edited 03-17-2019 05:25 AM
when phones (8961,7962 and 6921) are working on SRST mode, time is change (20 minutes different).
see below router configuration:
clock timezone Israel 2 0.
when working with cal manager time is correct.
01-06-2016 02:50 AM
Hey when the call manager is unreachable phones go srst local get there ntp/clock locally I presume so you need to adjust your clock on the router , routers are not very good NTP devices there algorithm would not be as good as the call manager , check your show clock detail to see if the time is NTP or just manually set on router and if its correct and then tweak it using clock set .........
01-06-2016 04:31 AM
NTP is configured.
But, when changing the clock timezone on the router, i dont see any change on the phone when running on SRST mode.
01-06-2016 05:57 AM
so when you change it does it change the time on the router but not on the phones , how long have you left the phones to sync for ? have your tried restarting one completely to see if it syncs quicker or try an extended ping from router to the phone.
01-07-2016 12:42 AM
just for testing, i remove the NTP server abd configured different time zone while phones are at SRST mode, but no change.
01-07-2016 03:15 AM
Can you post your router config from the SRST device?
01-10-2016 12:28 AM
01-06-2016 03:29 AM
Have you synced your router to NTP?
ntp server x.x.x.x
Aaron
