Phone doesn't register to CUCM
tazi mahmoud
I have an architecture where ip phones and  CUCM are in two separate networks trough Juniper Firewall
Ip phones : 30.30.30.0/24
CUCM : 172.18.1.65/24
DHCP is configured on Juniper Firewall and it delivers option 150 which is CUCM's ip address
ip phones get all parameters from dhcp server but don't get registered to CUCM
i tried an ip communicator and it works it got registered to CUCM
Please advise
5 Replies 5
Jaime Valencia
Are all the necessary ports open??
java
if this helps, please rate
To be sure i permit any to any from ip phones to cucm networks and from cucm to ip phones networks
OK, are the phones already configured in CUCM??
Or do you have auto-registration enabled?
java
I tried two possibilities
Phone already configured on call manager and new phone with auto registration enabled
An ipcomminicator works with auto registration but any other ip phone works (7821,8851,8845,7931) work
I don't understand what you mean here:
Assuming you meant to say those do NOT work, you'll need to drill down to sniffer traces and debugs to find out if the registration attempts are making it to CUCM, or not.
java
