04-02-2012
04:19 AM
- last edited on
03-25-2019
08:14 PM
by
ciscomoderator
I am just trying to add two ip phones to the ccm manually but they are showing regitrationi unknown. And both are the7962 new phones .They are showing some ip address of class A and not showing any option to change that.
04-02-2012 04:24 AM
1) Unlock phone by pressing **#
2) Erase configurationby selecting erase configuration option.
3) Disable DHCP on ip phone. And enter IP address, Default gateway, Subnet mast and TFTP (CUCM )ip address.
Ronak patel
Please rate helpful posts.
04-02-2012 04:32 AM
This is not working . Phone is not unlocking **# is not working . I have dailed it by hocking up and on hock as well.
04-02-2012 05:14 AM
Select settings, select Network configuration, scroll down to erase configuration which will be showing No next to it.
Now if you see a lock symbol on top right corner, press **# which will unlock it.
Now select Yes button to erase configuration.
04-02-2012 07:17 AM
So it looks like you DHCP is not working properly, make sure you have a scope defined for your voice vlan with option 150 defined that points to TFTP server.
HTH,
Chris
04-02-2012 09:07 PM
Actually i am adding these phones manually. Is it neccassry to define tftp server in case of manually. And what options i need to activate in servisability window.
04-02-2012 10:47 PM
not showing the option erase configuration
04-02-2012 11:38 PM
i got that thanks for telling me about the erase. It was really helpful
