05-30-2019 09:48 AM - edited 05-30-2019 04:25 PM
Hello Guys,
I got a SIP trunk from an ITSP but have been unable to register it. The problem is that the ITSP's SBC is rejecting my sip-ua registration request (from CME) because the requests coming from my CME are too many. MY Cisco 7945 PHONES ARE ALSO SENDING REGISTRATION REQUESTS TO THE ITSP. PLEASE HOW DO I STOP THIS? HELP!!!
May 30 17:08:59.893: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:cme.telecoms.com:5060 SIP/2.0
Via: SIP/2.0/UDP 41.xx.xx.xx:5060;branch=z9hG4bK5441614
To: <sip:1022@cme.telecoms.com>
Date: Thu, 30 May 2019 17:08:59 GMT
Call-ID: 3DF091F9-823111E9-B65BE35C-F9412332
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M5
Max-Forwards: 70
Timestamp: 1559236139
CSeq: 2 REGISTER
Contact: <sip:1022@41.xx.xx.xx:5060>
Expires: 3600
Supported: path
Content-Length: 0
May 30 17:08:59.901: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 41.xx.xx.xx:5060;branch=z9hG4bK5482262
To: <sip:1026@cme.telecoms.com>
Call-ID: 3DF12EBA-823111E9-B65FE35C-F9412332
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1026@41.xx.xx.xx:5060>
Expires: 3600
Supported: path
Content-Length: 0
May 30 17:09:00.041: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 41.xx.xx.xx:5060;branch=z9hG4bK552E16
To: <sip:1036@cme.telecoms.com>
Date: Thu, 30 May 2019 17:09:00 GMT
Call-ID: 3DF12EBA-823111E9-B669E35C-F9412332
Max-Forwards: 70
Timestamp: 1559236140
CSeq: 2 REGISTER
Contact: <sip:1036@41.xx.xx.xx:5060>
Expires: 3600
Supported: path
Content-Length: 0
May 30 17:09:00.053: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 41.xx.xx.xx:5060;branch=z9hG4bK554D8C
To: <sip:1038@cme.telecoms.com>
Call-ID: 3DF12EBA-823111E9-B66BE35C-F9412332
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1038@41.xx.xx.xx:5060>
Expires: 3600
Supported: path
Content-Length: 0
Solved! Go to Solution.
06-24-2019 03:44 AM - edited 05-24-2021 03:46 AM
So people who come after can find a solution. I already found a fix to this.
This solved it for me;
Go to ephone-dn and issue the "no-reg" command after "number xxxx no-reg". Example below;
ephone-dn 1 dual-line
number 1001 no-reg
label John Smith
description John Smith
I hope someone else finds this helpful
05-30-2019 02:51 PM
Is your CME a registrar server? What IPs does your phones have for TFTP servers?
Rolando A. Valenzuela
05-30-2019 04:51 PM - edited 05-30-2019 04:54 PM
Hello Rolando,
1. My CME is the registrar server (at least all phones can call each other-intercom and dial-peers)
2. The TFTP server address is the address of the CME 172.16.xx.xx
number 1001 no-reg
label John Smith
03-13-2021 03:46 AM
If someone wants to do the same for SIP phones:
There is no no-reg in voice register global, you only configure it in the dn:
voice register dn 1
number 1001
no-reg
If that doesn't work...
In my case, the router still sent the registration of the phone to the provider after that. I unplugged the phone, no change. I removed the phone (pool and dn) config, no change. I removed the sip-ua for the connection to the provider but once I moved it back, the router did the same thing. In the end, only a reload could fix the problem.
