02-28-2019 03:18 AM - edited 02-28-2019 03:20 AM
I’m planning to shift our office location to another so im asking about the ip cisco phones and cme that I already have , please check my below questions :
Cisco SMARTNET 8X5XNBD Cisco 2911 Voice Bundle
CISCO 2911 VOICE BUNDLE PVD 3-16 UC LICENSE PAK FL-CUBE 10 (whats is meaning by cube 10?)
Cisco 4 port voice interface card - fxo (ehwic)
CISCO UC PHONE 7945 Gig ETHERNET COLOR
CISCO UC PHONE 7821
Cisco Communication manager Express or SRST-25 Seat License
I HAVE BY THE WAY C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1
How many license that I have for now? Is it 25 seats only depending on what I mentioned above? What if I add more phones like 35 for example? Is it will work fine?
Please check the below output of show telephony-service :
Router#show telephony-service
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 192.168.2.207 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
load 7945 SCCP45.9-4-2SR3-1S
max-ephones 58
max-dn 64
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh flash:music-on-hold.au
time-format 24
date-format dd-mm-yy
timezone 25 Egypt Standard/Daylight Time
url services http://192.168.2.220/voiceview/common/login.do
url authentication http://192.168.2.220/voiceview/authentication/authenticate.do
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name amr password cisco
web admin customer name amr1 password cisco
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Dec 12 2018 12:24:03
transfer-system full-consult dss
transfer-digit-collect new-call
multicast moh 239.0.0.1 port 2000
route 192.168.2.207
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Router#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 03:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 11 weeks, 1 day, 31 minutes
System returned to ROM by reload at 12:35:02 EET Wed Dec 12 2018
System restarted at 12:38:23 EET Wed Dec 12 2018
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ190360AM
3 Gigabit Ethernet interfaces
1 terminal line
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FCZ190360AM
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
NtwkEss None None None
CollabPro None None None
And the correct connectivity is to put all cisco phones in one switch or doesnot matter if its divided on both switches and the power to feed over POE from switch to phones incase if all phones connected to one switch will be fine?
03-02-2019 02:55 PM
hello there i need help on my questions please :)
if any one can help by reading my questions please ill be glade for help
thanks
03-02-2019 02:59 PM - edited 03-02-2019 03:00 PM
- I have the following parts regarding my central ip :
CISCO 2911 VOICE BUNDLE PVD 3-16 UC LICENSE PAK FL-CUBE 01
CISCO UC PHONE 7821
1. I need to know how many ip cisco phones as maximum can I add and configure on my system.?
2. If I need to Buy more licenses for more phones on my ccme , how that ? And the license is per phone? also if I configure more phones than the quantity of licenses that I have is it will work fine ?
Please check the below output of show telephony-service : attached for your info maybe can help
- Technically connection setup :
3. I have 2 Switches 24 PORTS CATALYST 2960 - X SERIES GigE PoE 370W 4 X 1G SFP LAN Base (WS-C2960X-24PS-L)
4. What is the benefit if I put the voice traffic on separated vlan because I’m using only one vlan ( or I didn’t configure any vlans on my switches) ?
