I think this is a fairly basic question, but I am trying to send outbound fax calls from an FXS port to a PRI on a Cisco router (configured as H.323).
I have the inbound config OK (assign the FXS voice port an internal station ID, setup an inbound translation rule changing the DID to the station ID, setup a dial peer destination pattern matching the station ID and set it to the FXS port).
How do I do the inverse to get the FXS port to route out the PRI using an H.323 config?
