Phone License for Call Manager express - correct connection for phones on switch - max phones to configure
amralrazzaz
Level 5
Level 5
I’m planning to shift our office location to another so im asking about the ip cisco phones and cme that I already have , please check my below questions :
  • I have the following parts regarding my central ip :
Cisco SMARTNET 8X5XNBD Cisco 2911 Voice Bundle
CISCO 2911 VOICE BUNDLE PVD 3-16 UC LICENSE PAK FL-CUBE 10  (whats is meaning by cube 10?)
Cisco 4 port voice interface card - fxo (ehwic)
CISCO UC PHONE 7945 Gig ETHERNET COLOR
CISCO UC PHONE 7821
Cisco Communication manager Express or SRST-25 Seat License
I HAVE BY THE WAY C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1
  1. I need to know how many ip cisco phones as maximum can I add and configure on my system.?
               How many license that I have for now? Is it 25 seats only depending on what I mentioned above? What if I add more phones like 35 for example? Is it will work fine?
  1. If I need to Buy more licenses for more phones on my ccme , how that ? And the license is per phone? also if I configure more phones than the quantity of licenses that I have is it will work fine ?
Please check the below output of show telephony-service :
Router#show telephony-service
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 192.168.2.207 port 2000
ip qos dscp:
 ef (the MS 6 bits, 46, in ToS, 0xB8) for media
 cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
 af41 (the MS 6 bits, 34, in ToS, 0x88) for video
 default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
load 7945 SCCP45.9-4-2SR3-1S
max-ephones 58
max-dn 64
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh flash:music-on-hold.au
time-format 24
date-format dd-mm-yy
timezone 25 Egypt Standard/Daylight Time
url services http://192.168.2.220/voiceview/common/login.do
url authentication http://192.168.2.220/voiceview/authentication/authenticate.do
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name amr  password cisco
web admin customer name amr1  password cisco
edit DN through Web:  enabled.
edit TIME through web:  enabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Dec 12 2018 12:24:03
transfer-system full-consult dss
transfer-digit-collect new-call
multicast moh 239.0.0.1 port 2000
 route 192.168.2.207
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Router#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 03:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 11 weeks, 1 day, 31 minutes
System returned to ROM by reload at 12:35:02 EET Wed Dec 12 2018
System restarted at 12:38:23 EET Wed Dec 12 2018
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ190360AM
3 Gigabit Ethernet interfaces
1 terminal line
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO2911/K9          FCZ190360AM
Technology Package License Information for Module:'c2900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
uc            uck9                 Permanent      uck9
data          None                 None           None
NtwkEss       None                 None           None
CollabPro     None                 None           None
  • Technically connection setup :
  1. I have 2 Switches 24 PORTS CATALYST 2960 - X SERIES GigE PoE 370W 4 X 1G SFP LAN Base (WS-C2960X-24PS-L)
          And the correct connectivity is to put all cisco phones in one switch or doesnot matter if its divided       on both switches and the power to feed over POE from switch to phones incase if all phones connected to one switch will be fine?
  1. What is the benefit if I put the voice traffic on separated vlan because I’m using only one vlan ( or I didn’t configure any vlans on my switches) ?
amr alrazzaz
amralrazzaz
Level 5
Level 5
hello there i need help on my questions please :)
if any one can help by reading my questions please ill be glade for help
thanks
amr alrazzaz
amralrazzaz
Level 5
Level 5
- I have the following parts regarding my central ip :
CISCO 2911 VOICE BUNDLE PVD 3-16 UC LICENSE PAK FL-CUBE 01
CISCO UC PHONE 7821
2. If I need to Buy more licenses for more phones on my ccme , how that ? And the license is per phone? also if I configure more phones than the quantity of licenses that I have is it will work fine ?
Please check the below output of show telephony-service : attached for your info maybe can help
- Technically connection setup :
3. I have 2 Switches 24 PORTS CATALYST 2960 - X SERIES GigE PoE 370W 4 X 1G SFP LAN Base (WS-C2960X-24PS-L)
4. What is the benefit if I put the voice traffic on separated vlan because I’m using only one vlan ( or I didn’t configure any vlans on my switches) ?
amr alrazzaz
