06-01-2007 06:24 AM - edited 03-14-2019 09:50 PM
I'm having problems with Call Manager Express and the registration of ephones in that the phones do not obtain an IP address from the router. I've attached the config for the C2851 router and c3650 switch I'm using. The router software is c2800nm.spservicesk9-mz.124-3e.bin. The phone simply hangs displaying Configuring IP. The router console shows no activity, either does the debug dhcp events. Phones are 7940G, 7960G and 7961G. Phones are powered via PoE.
Solved! Go to Solution.
06-04-2007 05:08 AM
Many thanks to everyone that helped.
06-04-2007 12:42 PM
Glad to know it worked after all. Thanks and good luck!
