02-21-2014 07:04 AM - edited 03-16-2019 09:51 PM
The SRND states:
"Cisco Unified CM 9.x currently does not support the ASA Phone Proxy and TLS Proxy features."
Does anyone know if this is going to be supported in the future, if not what is the alternative solution?
Thanks in advance
Stewart
02-21-2014 07:09 AM
Phone proxy is being moved to CUBE (The last I heard was that not all phone features are currently supported)
GTG
Please rate all helpful posts.
02-21-2014 07:14 AM
Or you can use the phone built-in VPN feature, all discussed in the CUCM security guide on CCO
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
