Phone registration
Lasha Lomjaria
We have problem with registering cisco 6921 phone to CUCM 8.6.
We have about 400 phones and most of them are working fine, but some of them not registering.
They get ip address from DHCP, I can see phones as CDP neighbors but I cannot reach them. Ping doesn't work.
I tried to plug another phone in same switch port and it worked. Do you have any ideas?
20 Replies 20
hardware fault
or firmware bug
I had  firmware bug 9.1.1.0
Other working phones have same firmware, so it looks like hardware fault...
thank you.
Tagir Temirgaliyev
check firmware. probably you need latest.
Tagir Temirgaliyev
actually it is not the problem between cisco 6921 phone and CUCM 8.6.
if you can not ping 6921 phone from L3 switch so it is problem in IP or DHCP level or in VLANs or in subnets
thanks for reply,
When I connect another phone to same switch port it works fine, so its not Vlan and dhcp problem...
islam.kamal
Level 10
Level 10
Hello
1- Kindly do a factory reset for your phones which have problem.
if problem still exist
1- make sure that your IP phones one the correct voice vlan , check your L3 , check your intervlan configuration
if the problem still exist
1-go to phone physcially - setting - security setting - erase CTL & ITL .
1-try to connect one of the Ip phones which is registered properly before to the switch port which connected to ip phone which unable to register .
please rate all useful information
