Phone settings Cisco Unified IP Phone 7942G
vitali555md
Good afternoon, I have a big problem with the phone  Cisco 7942G. In phone settings, I pointed out that I can come on the  device into settings, but I can go into them, as I pointed out that I  could not go through the web, but I can go through the web. In the end,  what I set on the CallManager does not coincide with what it actually  is.I did factory reset using keyboard shortcuts, removed completely from  CallManager, changed the protocol for SIP SCCP, the same thing happens.  Maybe there are some settings that I do not know. Thanks in advance. Sorry for my English
Jonathan Schulenberg
You need to check override checkbox to the right of those settings, then apply config and reset the phone for it to take hold. Without that box checked, the phone will inhereit the behavior from a higher level (e.g. common phone profile, entperise phone configuration, or product default).
Please remember to rate helpful responses and identify helpful or correct answers.
