Phone status unregistered on Publisher
Phil Bradley
Level 4
Level 4
I just setup a subscriber in my CUCM 12.5 environment and moved a phone over to a new device pool that is pointing to the subscriber. The phone registered fine with the subscriber but the publisher shows unregistered for this phone. I have restarted the RIS data collector service on both pub and sub and also checked the db replication state and it shows 2-good. Any suggestions?
Phil Bradley
Level 4
Level 4
I checked this morning and it now shows the correct unified cm that it is registered to but the status still shows unregistered.
Ritesh Desai
@Phil Bradley  whats the active CUCM version you are using?
to get active CUCM version,
#show version active
There is latest SU2 version released and make sure you install. May be that fixes your issue.
Please rate helpful post. Please mark as answered if solves your problem.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
@Ritesh Desai
I’m on version 12.5.1.12900-115.
@Ritesh Desai
I actually just ran across another post with a user having the same issue and they restarted the Tomcat service and the registrations shows correct. I just restarted Tomcat on the publisher and the status is showing registered on the pub now.
