Phone to phone paging in CUCM 8.6.2
gary.hicks
I read somewhere that this was supposed to become available in version 8.6.2
Does anyone here know if it actually made it in the release and if so can you provide a link to configuration of it.
Thank you,
Gary Hicks
Jaime Valencia
There's no paging in CUCM, if you need 1:1 you could try the intercom feature.
1:many still required a 3rd party.
FYI if you need to check this kind of info it's always in the:
New and Changed Information for Cisco Unified  Communications Manager Release XXXX
Or within the RNs for each version.
They both contain what has been added and what changes you can expect.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
