Phones get stuck on VPN
Dennis1432
This morning when we came into the office, several phones are stuck in VPN mode, not sure what happened last night, they were fine day before yesterday. All phones are impacted, most are 8XXX series.
We tried reboot on one of the phone initially and that fixed the issue, but want to stop it going forward.
Mohammed-A.R.A
Check if the phones have VPN configuration or the call manager.
12 Replies 12
Mohammed-A.R.A
Was there any change recently? Is it recurring?
There was an Expressway certificate renewal recently but the phones were working fine for 2 days after that.
They are fine now, but each one required a reboot to fix the issue.
Ruben Cocheno
@Dennis1432
Check the logs of one of the phones to find more
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Thanks. Phones are remote. What are the logs we need to collect?
As Ruben have asked, Since phones are rebooted, I believe phone logs are wiped off. Do you see any phone which is not rebooted yet.
Mohammed-A.R.A
Is the issue resolved?
Are you using MRA or VPN?
Dennis1432
MRA
No phones ever use VPN since we decommissioned.
There is no issue, its the phones when they loose connection go back to VPN mode and always require a reboot.
Mohammed-A.R.A
Maxwell657
Have you identified any common patterns or similarities among the affected phones, such as specific models or configurations?
There are no specific models, we have all 88XX models.
Mohammed-A.R.A
Dennis1432
We need to change the common phone profile and common device configuration, as it has vpn profiles which are not in use, since phones are MRA devices. Once its removed, phones are asking for credentials and doesn't get stuck in vpn mode.
