09-20-2012 02:24 AM - edited 03-16-2019 01:18 PM
Would like to know the following,
The publisher and subscriber both show the phones of one particular cluster showing all the phones in unknown status but if we checked them physically the phones are registered well and able to make calls and received calls
Both of the version are 7.1
Alan
09-20-2012 05:11 AM
Hi Alan,
Could you please restart the Cisco RIS Data collector service, and let us know if it helps,
Som
06-18-2013 03:16 AM
Hi, I'm facing exactly the same issue. I tried restarting the RIS service on all the nodes but no luck.
Logged in to Sub webpage and checked the status of the phone, it is still incorrect status displaying.
Checked the DBreplication which is good
any idea would be much appreciated.
Suresh
06-18-2013 05:00 AM
it is not only for the phones but also MGCP endpoints which is showing as Rejected but in fact it is working and no issues reported
04-13-2015 05:27 AM
Suresh
Did the issue resolve?
I am facing the same issue now. Any suggestion?
Venkkatesh
04-13-2015 07:35 AM
Hi Venkkatesh
Can you verify, if the phone is showing incorrect status on just one of the nodes or all of them ?
This issue is mostly related to cucm nodes not able to poll the correct phone status .
Aditya Gupta
04-13-2015 07:50 AM
Aditya
Thanks for your response.
There are 5 nodes in the cluster ( 1Pub + 4Sub).
Phones are registered with subscriber.
If I login the subscriber web page, the status showing registered. But if I login Publisher web page the status showing unknown. Phones are Physically registered. I restarted the RIS service but no use. DB replication status showing 2.
Venkkatesh.L
04-13-2015 08:24 AM
On which node did u restarted the RIS DC service ?
What is CUCM Version ?
Aditya Gupta
04-13-2015 08:26 AM
On Publisher server where I am seeing status unknown.
CUCM version 9.1.2
Venkkatesh.L
04-13-2015 08:51 AM
Try to restart the RIS service on both sub and pub , then check if it improves the situation.
If the issue still persist, then most likely you ll need to restart the CCM service on sub and pub (if applicable) to clear out the old DB entries from the RAM of each server.
Aditya Gupta
04-21-2015 05:59 AM
The issue solved by restarting the Cisco Tomcat service on both publisher and affected Subscriber. Since the server is in production I cannot restart the server.
Thanks for your support
Venkkatesh.L
04-13-2015 05:26 AM
Alan
Venkkatesh
06-12-2018 11:32 AM
I had the same problem, phones were showing 'unregistered' in cucm but the actual phone was working and able to make calls.
I restart the "Cisco RIS Data Collector" in Serviceability and this fixed the problem.
08-13-2018 03:08 AM
I have the same problen in v.11.5.1.14900-11. I restarted Cisco RIS Data Collector in PUB and the problem has been fixed.
Regards.
11-08-2018 07:30 AM
Same here,
Status of some phones from a specific subscriber were unknown only on the publisher.
version 11.5.1.13901-3 , after restart of RIS Data Collector on the pub problem is gone, for now.
