phones supported for cucm version 11
alanhow2007
Would like to know the phone models supported for cucm version 11 and where to get the document to be found ?
Thank you
5 Replies 5
Jitender Bhandari
Below is the list of all the phones and firmware
http://www.cisco.com/web/software/282074295/136664/cucm-readme-1151su2.pdf
Check the Firmware Versions in this Release section of above link
(Rate if it helps)
JB
You can also login to "Cisco Unified Reporting" on your CUCM server and then click on "System report and then click on
Unified CM Phone Feature List
It will tell you all the devices supported and features supported by those devices.
(Rate if it helps)
JB
Hamzeh Alzubi
You can check Cisco Collaboration Systems Release Compatibility Matrix here:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix.html
Then either check PDF or HTML formats.
Rajan
Pls refer the below link:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_5_1/cucm_b_release-notes-cucm-imp-1151/cucm_b_release-notes-cucm-imp-1151_chapter_010.html
Rajan
Pls rate all useful posts
Jitender Bhandari
(Rate if it helps)
JB
