08-01-2016 01:31 AM - edited 03-17-2019 07:42 AM
Hi All,
I have 4-5 user in a call Pick Up group but 2 user complaint that when they try to pick up other user call "Pick Up" soft button doesn't work.
What can be possible reason.
I have done following verification.
1. Pick Up group configuration
2. Directory Number (to check whether each user has been added to this group)
08-01-2016 01:44 AM
Can you verify the Call Pickup config as per the following doc
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsgd-712-cm/fscpickg.html#wp1124140
Check for any overlapping unassigned directory numbers in the Route Plan report and delete them. You can also compare the settings of the working DN's of the pickup group with those that are not working and try configuring pick up group members on a different phone as a test. If all of this fails then you will require detailed callmanager service traces for a test call where pickup does not work.
Manish
08-01-2016 09:03 PM
Hi Manish,
I am working on it. I 'll get back to you.
08-01-2016 09:38 PM
Thanks Manish, It worked simply. I just created new test group moved user in that and it worked.
08-01-2016 10:24 PM
Good to know that, thanks for updating the post.
Manish
