04-26-2013
12:02 PM
- last edited on
03-25-2019
08:22 PM
by
ciscomoderator
Hi All,
Is there a way to pick-up a call by using a "code" on Analog Sets in a CUCM environment ?
Thanks in advanced.
Solved! Go to Solution.
04-26-2013 03:20 PM
You will need to setup Supplementary Features. Look this example:
Step 4 – Configure your Analog Phones supplementary features (optional Step – only if you needed these features, otherwise move to step 5)
stcapp feature access-code
prefix *
call forward all …your code Example 18..
call forward cancel …..your code Example 17……
pickup local your code Example 22…..
Etc…. So now to use call forward all on your analog phone you need to press *18 then the extension you would like to forward
your calls to..
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
04-26-2013 01:05 PM
What kind of analog set are you working with, ATA (Cisco 186/187), MGCP FXS or SCCP FXS?
04-26-2013 02:44 PM
I´m actually working with SCCP sets that come from a VG224.
Thanks in advance.
04-26-2013 03:20 PM
prefix *
your calls to..
04-26-2013 05:28 PM
Thaks a Lot,
04-27-2013 04:39 AM
You're welcome :)
Sent from Cisco Technical Support Android App
