Pick up calls with Analog sets
    Hi All,
Is there a way to pick-up a call by using a "code" on Analog Sets in a CUCM environment  ?
Thanks in advanced.
You will need to setup Supplementary Features. Look this example:
Step 4 – Configure your Analog Phones supplementary features (optional Step – only if you needed these features, otherwise move to step 5)
stcapp feature access-code
prefix *
call forward all …your code Example 18..
call forward cancel …..your code Example 17……
pickup local your code Example 22…..
Etc…. So now to use call forward all on your analog phone you need to press *18 then the extension you would like to forward
your calls to..
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
5 Replies 5
What kind of analog set are you working with, ATA (Cisco 186/187), MGCP FXS or SCCP FXS?
I´m actually working with SCCP sets that come from a VG224.
Thanks in advance.
prefix *
your calls to..
Thaks a Lot,
You're welcome :)
Sent from Cisco Technical Support Android App
