PIN protected extension / Multi Dial Extension for overhead paging speakers
AbteenZ
I've been assigned a task to add some overhead paging speakers to CUCM.
I've been asked to assign an extension per zone that is protected by PIN.
Also define and extension that dials all the 5 zones at once.
How this is possible?
5 Replies 5
Jaime Valencia
CUCM only provides FAC/CMC, if the device is going to be reached via a route pattern, you can use them.
java
if this helps, please rate
Could you please explain more? an example is much appreciated.
Regarding a 2nd part, you can create a hunt pilot which points to 5 zones and hunting type as broadcast
AbteenZ
Has anyone ever implemented something like this easily?
Can I do this with UCCX scripts or even unity?
