POE and 7940 ip phone
qwest5555
I have a 2811-ac-ip with a NME-16ES-1G-P card install I can get a 7941 to power up, but the phone I have are a 7940 and they will not power up. The swith is running 3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5. Please help
5 Replies 5
thisisshanky
Level 11
Level 11
Have you tried powering this particular phone on another inline power switch ? Just wondering if its a bad phone?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Rob Huffman
Hi Douglas,
It sounds like this bug (Thanks Met!);
CSCsi70300 Bug Details
NME Etherswitch Service Module Not Detecting Pre-Standard Devices
Symptom:
Pre-Standard POE devices are not powering up, link is down/down.
Conditions:
PreStd POE device must be connected to Etherswitch Service Module (ex. NME-16ES-1G-P) running 12.2(35)SE2.
Workaround:
Downgrade IOS to 12.2(25)SEE3
Further Problem Description:
Althought the NME runs 3750 IOS, the problem is not seen on a 3750 switch.
The IEEE 802.3af devices function fine (ex. 7961, 7941), only Pre-Std are affected.
Hope this helps!
Rob
Downgraded switch to IOS to 12.2(25)SEE3
Everything work great !!
Thnaks
Doug
If you need to run a later version of IOS for other features this defect is resolved in 12.2(40)SE or later.
I'm seeing similiar behavior on my Cisco 1801.
POE - power supply is connected and POE LED is green, but when I connect 7941 phone it does not power up.
I'm running IOS Version 12.4(11)T4.
The inline power config is set for auto on all ports and a 'show power inline' sees an 80 watt power supply, but nothing allocated to any of the ports.
Any thoughts would be greatly appreciated.
Thanks...matt
