pointed toll-free voicemail to internal EXT
Laith7640
I am new to this Cisco VOIP system. I need to know where I can find the toll free number details. I had a request today to move the voicemail from the existing  user to another user . I Need The toll free is 866.x.x.x.x  Voicemail to pointed to Ext 2122 or email address for that user
I cant see anywhere , any need help please
set by step how to do that ...... please
Wilson Samuel
Level 7
Level 7
Toll Free Numbers are always pointed towards the Toll Numbers, i.e. when you dial any toll free number e.g. 1-800-553-2447 , it rings some where a toll number e.g. 1 408-526-7209
So here are the steps you may want to follow:
1. On the GW (presuming it is PRI) start a debug (debug isdn q931)
2. Dial the Toll Free Number and you should see your Calling Number and the Toll Number as the Called Number
3. Once you know the Toll Number, follow the Call Flow in the CCM (start from GW and then Translation Pattern etc) and see where the call is landing
4. Once you know the exact DN and the configuration on the DN you can change the parameters in the Unity Connection (voicemail) for the Toll Free
Please let us know if any further issues
10 Replies 10
Dennis Mink
what does this toll free number do? and when is it called?  and what is your voicemail system? Unity Connection?
Please remember to rate useful posts, by clicking on the stars below.
This toll-free Number is for getting voicemail only , if some one call this number will take him to the voicemail
The Voicemail system is Unity
Thansk
Wilson Samuel
Level 7
Level 7
Wilson could you please tell me how to Debug isdn q931 am not familiar with unity or call manager
just basic things
Thx
If I run debug isdn q931 on the router its not going to effect anything .
cos like you know  sometimes if you do debug on the router they might crash it
so it is safe to run  debug isdn q931
Laith7640
what to do mean off GW , I do not to debug
Laith7640
I got some output I can see my number and other , could you please tell me what I have to do as next step .
Please elaborate and we shall be glad to help you in any way we can.
Laith7640
Big Thanks Wilson its working fine know .
Laith7640
