Polycom FXS
mightyking
Level 6
Level 6
Hello Everyone,
Polycom SoundStation 2 connected to a FXS on a VG350 MGCP using SCCP. Unable to make a conference call. We are able to connect with the 1st caller, but when we press the button to add a conference participant, communication is cut with 1st caller, and we hear the dialtone.
I have increased the timer Hookflash without success. I also added a 2nd DN, again no success.
It looks like the port does not support the max call 2. All features codes work perfectely fine.
CUCM version: 8.6
VG350 Version 15.5(3)M1
Polycome SoundStation 2  SCCP
voice-port 2/0/21
 vmwi dc-voltage
 mwi
 cptone CA
 timeouts ringing infinity
 timing hookflash-in 150 70
dial-peer voice 2020 pots
 service mgcpapp
 port 2/0/20
dial-peer voice 2021 pots
 service stcapp
 port 2/0/21
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
DSP    DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
                           *DSP SIGNALING CHANNELS*
SP2600 001 01 {flex}        40.2.4 alloc idle      0  0 2/0/0     02    0        203/0
SP2600 001 02 {flex}        40.2.4 alloc idle      0  0 2/0/1     02    0        104/0
SP2600 001 03 {flex}        40.2.4 alloc idle      0  0 2/0/2     06    0         76/0
SP2600 001 04 {flex}        40.2.4 alloc idle      0  0 2/0/3     06    0         70/0
SP2600 001 05 {flex}        40.2.4 alloc idle      0  0 2/0/4     10    0         68/0
SP2600 001 06 {flex}        40.2.4 alloc idle      0  0 2/0/5     10    0         61/0
SP2600 001 07 {flex}        40.2.4 alloc idle      0  0 2/0/6     14    0        137/0
SP2600 001 08 {flex}        40.2.4 alloc idle      0  0 2/0/7     14    0          2/0
SP2600 001 09 {flex}        40.2.4 alloc idle      0  0 2/0/8     18    0         55/0
SP2600 001 10 {flex}        40.2.4 alloc idle      0  0 2/0/9     18    0         55/0
SP2600 001 11 {flex}        40.2.4 alloc idle      0  0 2/0/10    22    0         55/0
SP2600 001 12 {flex}        40.2.4 alloc idle      0  0 2/0/11    22    0         55/0
SP2600 001 13 {flex}        40.2.4 alloc idle      0  0 2/0/12    26    0         55/0
SP2600 001 14 {flex}        40.2.4 alloc idle      0  0 2/0/13    26    0         55/0
SP2600 001 15 {flex}        40.2.4 alloc idle      0  0 2/0/14    30    0         55/0
SP2600 001 16 {flex}        40.2.4 alloc idle      0  0 2/0/15    30    0         75/0
SP2600 001 17 {flex}        40.2.4 alloc idle      0  0 2/0/16    02    0         95/0
SP2600 001 18 {flex}        40.2.4 alloc idle      0  0 2/0/17    02    0         55/0
SP2600 001 19 {flex}        40.2.4 alloc idle      0  0 2/0/18    06    0       1866/0
SP2600 001 20 {flex}        40.2.4 alloc idle      0  0 2/0/19    06    0          2/0
SP2600 001 21 {flex}        40.2.4 alloc idle      0  0 2/0/20    10    0         61/0
SP2600 001 22 {flex}        40.2.4 alloc idle      0  0 2/0/21    10    0        101/0
SP2600 001 23 {flex}        40.2.4 alloc idle      0  0 2/0/22    14    0         55/0
SP2600 001 24 {flex}        40.2.4 alloc idle      0  0 2/0/23    14    0         85/0
SP2600 001 25 {flex}        40.2.4 alloc idle      0  0 2/0/24    02    0        118/0
SP2600 001 26 {flex}        40.2.4 alloc idle      0  0 2/0/25    02    0        637/0
SP2600 001 27 {flex}        40.2.4 alloc idle      0  0 2/0/26    06    0         64/0
SP2600 001 28 {flex}        40.2.4 alloc idle      0  0 2/0/27    06    0        133/0
SP2600 001 29 {flex}        40.2.4 alloc idle      0  0 2/0/28    10    0         73/0
SP2600 001 30 {flex}        40.2.4 alloc idle      0  0 2/0/29    10    0        324/0
SP2600 001 31 {flex}        40.2.4 alloc idle      0  0 2/0/30    14    0        116/0
SP2600 001 32 {flex}        40.2.4 alloc idle      0  0 2/0/31    14    0        203/0
SP2600 001 33 {flex}        40.2.4 alloc idle      0  0 2/0/32    02    0         60/0
SP2600 001 34 {flex}        40.2.4 alloc idle      0  0 2/0/33    02    0         64/0
SP2600 001 35 {flex}        40.2.4 alloc idle      0  0 2/0/34    06    0        293/0
SP2600 001 36 {flex}        40.2.4 alloc idle      0  0 2/0/35    06    0          2/0
SP2600 001 37 {flex}        40.2.4 alloc idle      0  0 2/0/36    10    0         54/0
SP2600 001 38 {flex}        40.2.4 alloc idle      0  0 2/0/37    10    0         54/0
SP2600 001 39 {flex}        40.2.4 alloc idle      0  0 2/0/38    14    0         54/0
SP2600 001 40 {flex}        40.2.4 alloc idle      0  0 2/0/39    14    0         54/0
SP2600 001 41 {flex}        40.2.4 alloc idle      0  0 2/0/40    18    0         54/0
SP2600 001 42 {flex}        40.2.4 alloc idle      0  0 2/0/41    18    0         54/0
SP2600 002 01 {flex}        40.2.4 alloc idle      0  0 4/0/0     02    0         94/0
SP2600 002 02 {flex}        40.2.4 alloc idle      0  0 4/0/1     02    0        147/0
SP2600 002 03 {flex}        40.2.4 alloc idle      0  0 4/0/2     06    0        565/0
SP2600 002 04 {flex}        40.2.4 alloc idle      0  0 4/0/3     06    0        125/0
SP2600 002 05 {flex}        40.2.4 alloc idle      0  0 4/0/4     10    0         55/0
SP2600 002 06 {flex}        40.2.4 alloc idle      0  0 4/0/5     10    0        160/0
SP2600 002 07 {flex}        40.2.4 alloc idle      0  0 4/0/6     14    0         72/0
SP2600 002 08 {flex}        40.2.4 alloc idle      0  0 4/0/7     14    0        255/0
SP2600 002 09 {flex}        40.2.4 alloc idle      0  0 4/0/8     18    0         55/0
SP2600 002 10 {flex}        40.2.4 alloc idle      0  0 4/0/9     18    0        175/0
SP2600 002 11 {flex}        40.2.4 alloc idle      0  0 4/0/10    22    0          2/0
SP2600 002 12 {flex}        40.2.4 alloc idle      0  0 4/0/11    22    0          2/0
SP2600 002 13 {flex}        40.2.4 alloc idle      0  0 4/0/12    26    0         88/0
SP2600 002 14 {flex}        40.2.4 alloc idle      0  0 4/0/13    26    0        115/0
SP2600 002 15 {flex}        40.2.4 alloc idle      0  0 4/0/14    30    0        151/0
SP2600 002 16 {flex}        40.2.4 alloc idle      0  0 4/0/15    30    0        171/0
SP2600 002 17 {flex}        40.2.4 alloc idle      0  0 4/0/16    02    0         75/0
SP2600 002 18 {flex}        40.2.4 alloc idle      0  0 4/0/17    02    0         76/0
SP2600 002 19 {flex}        40.2.4 alloc idle      0  0 4/0/18    06    0         58/0
SP2600 002 20 {flex}        40.2.4 alloc idle      0  0 4/0/19    06    0         55/0
SP2600 002 21 {flex}        40.2.4 alloc idle      0  0 4/0/20    10    0         87/0
SP2600 002 22 {flex}        40.2.4 alloc idle      0  0 4/0/21    10    0         55/0
SP2600 002 23 {flex}        40.2.4 alloc idle      0  0 4/0/22    14    0         55/0
SP2600 002 24 {flex}        40.2.4 alloc idle      0  0 4/0/23    14    0          2/0
SP2600 002 25 {flex}        40.2.4 alloc idle      0  0 4/0/24    02    0        179/0
SP2600 002 26 {flex}        40.2.4 alloc idle      0  0 4/0/25    02    0         55/0
SP2600 002 27 {flex}        40.2.4 alloc idle      0  0 4/0/26    06    0         55/0
SP2600 002 28 {flex}        40.2.4 alloc idle      0  0 4/0/27    06    0         55/0
SP2600 002 29 {flex}        40.2.4 alloc idle      0  0 4/0/28    10    0        256/0
SP2600 002 30 {flex}        40.2.4 alloc idle      0  0 4/0/29    10    0        923/0
SP2600 002 31 {flex}        40.2.4 alloc idle      0  0 4/0/30    14    0        219/0
SP2600 002 32 {flex}        40.2.4 alloc idle      0  0 4/0/31    14    0        184/0
SP2600 002 33 {flex}        40.2.4 alloc idle      0  0 4/0/32    02    0        199/0
SP2600 002 34 {flex}        40.2.4 alloc idle      0  0 4/0/33    02    0        419/0
SP2600 002 35 {flex}        40.2.4 alloc idle      0  0 4/0/34    06    0         80/0
SP2600 002 36 {flex}        40.2.4 alloc idle      0  0 4/0/35    06    0        114/0
SP2600 002 37 {flex}        40.2.4 alloc idle      0  0 4/0/36    10    0        105/0
SP2600 002 38 {flex}        40.2.4 alloc idle      0  0 4/0/37    10    0        125/0
SP2600 002 39 {flex}        40.2.4 alloc idle      0  0 4/0/38    14    0        162/0
SP2600 002 40 {flex}        40.2.4 alloc idle      0  0 4/0/39    14    0         57/0
SP2600 002 41 {flex}        40.2.4 alloc idle      0  0 4/0/40    18    0        108/0
SP2600 002 42 {flex}        40.2.4 alloc idle      0  0 4/0/41    18    0        245/0
SP2600 003 01 {flex}        40.2.4 alloc idle      0  0 4/0/42    22    0        136/0
SP2600 003 02 {flex}        40.2.4 alloc idle      0  0 4/0/43    22    0         71/0
SP2600 003 03 {flex}        40.2.4 alloc idle      0  0 4/0/44    26    0         60/0
SP2600 003 04 {flex}        40.2.4 alloc idle      0  0 4/0/45    26    0        104/0
SP2600 003 05 {flex}        40.2.4 alloc idle      0  0 4/0/46    30    0        129/0
SP2600 003 06 {flex}        40.2.4 alloc idle      0  0 4/0/47    30    0       1130/0
SP2600 003 07 {flex}        40.2.4 alloc idle      0  0 4/0/48    02    0         62/0
SP2600 003 08 {flex}        40.2.4 alloc idle      0  0 4/0/49    02    0          2/0
SP2600 003 09 {flex}        40.2.4 alloc idle      0  0 4/0/50    06    0          2/0
SP2600 003 10 {flex}        40.2.4 alloc idle      0  0 4/0/51    06    0          2/0
SP2600 003 11 {flex}        40.2.4 alloc idle      0  0 4/0/52    10    0          2/0
SP2600 003 12 {flex}        40.2.4 alloc idle      0  0 4/0/53    10    0          2/0
SP2600 003 13 {flex}        40.2.4 alloc idle      0  0 4/0/54    14    0          2/0
SP2600 003 14 {flex}        40.2.4 alloc idle      0  0 4/0/55    14    0          2/0
SP2600 003 15 {flex}        40.2.4 alloc idle      0  0 4/0/56    18    0          2/0
SP2600 003 16 {flex}        40.2.4 alloc idle      0  0 4/0/57    18    0          2/0
SP2600 003 17 {flex}        40.2.4 alloc idle      0  0 4/0/58    22    0          2/0
SP2600 003 18 {flex}        40.2.4 alloc idle      0  0 4/0/59    22    0          2/0
SP2600 003 19 {flex}        40.2.4 alloc idle      0  0 4/0/60    26    0          2/0
SP2600 003 20 {flex}        40.2.4 alloc idle      0  0 4/0/61    26    0          2/0
SP2600 003 21 {flex}        40.2.4 alloc idle      0  0 4/0/62    30    0          2/0
SP2600 003 22 {flex}        40.2.4 alloc idle      0  0 4/0/63    30    0          2/0
SP2600 003 23 {flex}        40.2.4 alloc idle      0  0 4/0/64    02    0          2/0
SP2600 003 24 {flex}        40.2.4 alloc idle      0  0 4/0/65    02    0          2/0
SP2600 003 25 {flex}        40.2.4 alloc idle      0  0 4/0/66    06    0          2/0
SP2600 003 26 {flex}        40.2.4 alloc idle      0  0 4/0/67    06    0          2/0
SP2600 003 27 {flex}        40.2.4 alloc idle      0  0 4/0/68    10    0          2/0
SP2600 003 28 {flex}        40.2.4 alloc idle      0  0 4/0/69    10    0          2/0
SP2600 003 29 {flex}        40.2.4 alloc idle      0  0 4/0/70    14    0          2/0
SP2600 003 30 {flex}        40.2.4 alloc idle      0  0 4/0/71    14    0          2/0
SP2600 006 01 {flex}        40.2.4 alloc idle      0  0 2/0/42    22    0         56/0
SP2600 006 02 {flex}        40.2.4 alloc idle      0  0 2/0/43    22    0        101/0
SP2600 006 03 {flex}        40.2.4 alloc idle      0  0 2/0/44    26    0        167/0
SP2600 006 04 {flex}        40.2.4 alloc idle      0  0 2/0/45    26    0         54/0
SP2600 006 05 {flex}        40.2.4 alloc idle      0  0 2/0/46    30    0         66/0
SP2600 006 06 {flex}        40.2.4 alloc idle      0  0 2/0/47    30    0         78/0
SP2600 006 07 {flex}        40.2.4 alloc idle      0  0 2/0/48    02    0         57/0
SP2600 006 08 {flex}        40.2.4 alloc idle      0  0 2/0/49    02    0         54/0
SP2600 006 09 {flex}        40.2.4 alloc idle      0  0 2/0/50    06    0         66/0
SP2600 006 10 {flex}        40.2.4 alloc idle      0  0 2/0/51    06    0         79/0
SP2600 006 11 {flex}        40.2.4 alloc idle      0  0 2/0/52    10    0         57/0
SP2600 006 12 {flex}        40.2.4 alloc idle      0  0 2/0/53    10    0        236/0
SP2600 006 13 {flex}        40.2.4 alloc idle      0  0 2/0/54    14    0         54/0
SP2600 006 14 {flex}        40.2.4 alloc idle      0  0 2/0/55    14    0        319/0
SP2600 006 15 {flex}        40.2.4 alloc idle      0  0 2/0/56    18    0         64/0
SP2600 006 16 {flex}        40.2.4 alloc idle      0  0 2/0/57    18    0        111/0
SP2600 006 17 {flex}        40.2.4 alloc idle      0  0 2/0/58    22    0       2313/0
SP2600 006 18 {flex}        40.2.4 alloc idle      0  0 2/0/59    22    0        892/0
SP2600 006 19 {flex}        40.2.4 alloc idle      0  0 2/0/60    26    0        510/0
SP2600 006 20 {flex}        40.2.4 alloc idle      0  0 2/0/61    26    0         78/0
SP2600 006 21 {flex}        40.2.4 alloc idle      0  0 2/0/62    30    0         60/0
SP2600 006 22 {flex}        40.2.4 alloc idle      0  0 2/0/63    30    0        152/0
SP2600 006 23 {flex}        40.2.4 alloc idle      0  0 2/0/64    02    0          2/0
SP2600 006 24 {flex}        40.2.4 alloc idle      0  0 2/0/65    02    0         60/0
SP2600 006 25 {flex}        40.2.4 alloc idle      0  0 2/0/66    06    0        308/0
SP2600 006 26 {flex}        40.2.4 alloc idle      0  0 2/0/67    06    0        757/0
SP2600 006 27 {flex}        40.2.4 alloc idle      0  0 2/0/68    10    0         54/0
SP2600 006 28 {flex}        40.2.4 alloc idle      0  0 2/0/69    10    0        107/0
SP2600 006 29 {flex}        40.2.4 alloc idle      0  0 2/0/70    14    0        213/0
SP2600 006 30 {flex}        40.2.4 alloc idle      0  0 2/0/71    14    0         60/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
MK
mightyking
Level 6
Level 6
Anybody????
Here're some outputs after being connected to the 1st caller,
LQ500-R25V#sh sccp conn
Total number of active session(s) 0, and connection(s) 0
LQ500-R25V#sh dspfar dsp active
SLOT   DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
Total number of DSPFARM DSP channel(s) 0
MK
I am reaching out to you one more time before opening a TAC Case?
MK
New development!
We are not even able to conference-in internal phones using 5 digits dialing. As soon as the conference botton is press the first call is lost. Anybody experienced anything similar? Could that be becasue the line does not support the 2nd call? although in the line configuration page I allow maximum number of call = 2.
MK
