Polycom phone dialling issue
problemchild27
                        Am having dialling problem with Polycom phone. Am able to register and make local calls. but not able to dial Long distance. I have not created any seperate dialling pattern.
CUCM7.1.3
5 digit dialling works
0xxx-xxx-xxxx works
00 doesnot work. After dialling 00 am getting fast busy
Any suggestion???
Thanks inadvance
acampbell
Check the CSS of the line/phone, does it have access to
the partition that hosts the 00 route patterns
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
      Thanks for your reply. It was not the problem with CSS. Polycom phones by default has only this dial plan: [2-9]11|0T|011xxx.T|[0-1][2-9]xxxxxxxxxx|[2-9]xxxxxxxxx|[2-9]xxxT|.  I login to the web browser and figured it out. Thank you
