Possible to make Time of day routing in cisco unity connection 8?
gobidurai
Hi All,
In my organization, one of the secretary(1) wants whenever his manager phone is no answer or busy on Monday, Tuesday call should be fwded to her phone and Wed-Friday call should go to different secretary(2) phone.
To avoid creating Transl.patt , PT, CSS in cucm time of day routing,  Is it possible to achieve the same via CUC 8?  I tried using Call Handler, but first caller was prompted for greeting then transfered if mgr ph. is busy.  Is there any other way ? pls. advice.
Jaime Valencia
You would need to configure a schedule and then the std and closed greetings each one with the action you want.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
