Postage machine with VG202
rusty.dober
I've read all the posts but haven't seen any clear signs of success with being able to get a VG202 to work with a postage machine.
Of course, fax machines work without any issues but it's just with the postage machine.
The postage machine we're using is a CentorMail. The devices seem to get connected but then the call is dropped.
The VG202 has 15.1 on it and CallManager is 8.6
Call flow: Postage machine - VG202(Port 0/0)- H323 - CUCM 8.6 - H323 - 3900 VG w/ PRI - ISDN provider
VG202 config
stcapp register capability 0/0 modem-passthrough
stcapp ccm-group 1
stcapp
stcapp supplementary-services
 port 0/0
  fallback-dn 1998
 port 0/1
  fallback-dn 1997
voice service voip
 fax protocol pass-through g711ulaw
 modem passthrough nse codec g711ulaw
voice-card 0
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 192.168.1.2  255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
voice-port 0/0
 input gain 6
 output attenuation 10
 timeouts initial 60
 timeouts interdigit 60
 timeouts ringing infinity
voice-port 0/1
ccm-manager sccp local FastEthernet0/0
mgcp profile default
sccp ccm 10.2.40.12 identifier 1 priority 1 version 7.0
sccp ccm 10.90.50.12 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
dial-peer voice 1 pots
 service stcapp
 port 0/0
dial-peer voice 2 pots
 service stcapp
 port 0/1
line con 0
 exec-timeout 0 0
 login local
line aux 0
 login local
line vty 0 4
 login local
 transport input all
Hi.
I suggest you to configure a voip dialpeer on your 3900 VG with answer-address option to match calling number  of VG202 port and set modem passthrough option.
Eg.
DN configured on VG port :5900
dial-peer voice XX voip
answer-address 5900
codec g711ulaw
dtmf-relay h245-alphanumeric
no vad
Carlo
Please rate all helpful posts "The more you help the more you learn"
