Pots dial-peers not match
hugomdbaez
Hello to all
I have a router Cisco 2821 and 4 analog lines in FXO ports , when i place a call from outside i heard the IVR but the hunt of phones not rings , here is the sh voice call stat
Router#sh voice call stat
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x1620D    613  0x4B0CECCC 2/0/8            0/1:1   9000       None     208/20186
0x16210    613  0x4CE25A04 50/0/2.0                *9000       None      20186/208
1 active call found
Router#sh dial-peer voice summ
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
100    voip  up   up                                0  syst
101    pots  up   up             0[3-7]......       0                      down trunkgroup PSTN
102    pots  up   up   15        015.......         0                      down trunkgroup PSTN
103    pots  up   up   0         00[3-7]T           0                      down trunkgroup PSTN
104    pots  up   up   00        000T               0                      down trunkgroup PSTN
105    pots  up   up   08        008T               0                      down trunkgroup PSTN
106    pots  up   up             01[^5].            0                      down trunkgroup PSTN
107    pots  up   up             0911               0                      down trunkgroup PSTN
108    pots  up   up             00[1-3].15......-  0                      down trunkgroup PSTN
109    pots  up   up             00[1-3].........   0                      down trunkgroup PSTN
110    pots  up   up             00[1-3]...15....-  0                      down trunkgroup PSTN
111    pots  up   up             00[1-3]..15.....-  0                      down trunkgroup PSTN
20001  pots  up   up             9011$              0                           50/0/1
20002  pots  up   up             9002$              0                           50/0/2
20003  pots  up   down                              0                           50/0/3
20004  pots  up   down                              0                           50/0/4
20005  pots  up   down                              0                           50/0/5
20006  pots  up   down                              0                           50/0/6
20007  pots  up   down                              0                           50/0/7
20008  pots  up   down                              0                           50/0/8
20009  pots  up   down                              0                           50/0/9
20010  pots  up   down                              0                           50/0/10
20011  pots  up   down                              0                           50/0/11
20012  pots  up   down                              0                           50/0/12
20013  pots  up   down                              0                           50/0/13
20014  pots  up   down                              0                           50/0/14
20015  pots  up   down                              0                           50/0/15
20016  pots  up   down                              0                           50/0/16
20017  pots  up   down                              0                           50/0/17
20018  pots  up   down                              0                           50/0/18
20019  pots  up   down                              0                           50/0/19
20020  pots  up   down                              0                           50/0/20
20021  pots  up   down                              0                           50/0/21
20022  pots  up   down                              0                           50/0/22
20023  pots  up   down                              0                           50/0/23
20024  pots  up   down                              0                           50/0/24
20025  pots  up   down                              0                           50/0/25
20026  pots  up   down                              0                           50/0/26
20027  pots  up   down                              0                           50/0/27
20028  pots  up   down                              0                           50/0/28
20029  pots  up   down                              0                           50/0/29
20030  pots  up   down                              0                           50/0/30
20031  pots  up   down                              0                           50/0/31
20032  pots  up   down                              0                           50/0/32
20033  pots  up   down                              0                           50/0/33
20034  pots  up   down                              0                           50/0/34
20035  pots  up   down                              0                           50/0/35
20036  pots  up   down                              0                           50/0/36
20037  pots  up   down                              0                           50/0/37
20038  pots  up   down                              0                           50/0/38
20039  pots  up   down                              0                           50/0/39
20040  pots  up   down                              0                           50/0/40
20041  pots  up   down                              0                           50/0/41
             AD                                    PRE PASS                OUT
20042  pots  up   down                              0                           50/0/42
20043  pots  up   down                              0                           50/0/43
20044  pots  up   down                              0                           50/0/44
20045  pots  up   down                              0                           50/0/45
20046  pots  up   down                              0                           50/0/46
20047  pots  up   down                              0                           50/0/47
20048  pots  up   down                              0                           50/0/48
20049  pots  up   down                              0                           50/0/49
20050  pots  up   down                              0                           50/0/50
20051  pots  up   down                              0                           50/0/51
20052  pots  up   down                              0                           50/0/52
20053  pots  up   down                              0                           50/0/53
20054  pots  up   down                              0                           50/0/54
20055  pots  up   down                              0                           50/0/55
20056  pots  up   down                              0                           50/0/56
20057  pots  up   down                              0                           50/0/57
20058  pots  up   down                              0                           50/0/58
20059  pots  up   down                              0                           50/0/59
20060  pots  up   down                              0                           50/0/60
20061  pots  up   down                              0                           50/0/61
20062  pots  up   down                              0                           50/0/62
20063  pots  up   down                              0                           50/0/63
20064  pots  up   down                              0                           50/0/64
20065  pots  up   down                              0                           50/0/65
20066  pots  up   down                              0                           50/0/66
20067  pots  up   down                              0                           50/0/67
20068  pots  up   down                              0                           50/0/68
20069  pots  up   down                              0                           50/0/69
20070  pots  up   down                              0                           50/0/70
20071  pots  up   down                              0                           50/0/71
20072  pots  up   down                              0                           50/0/72
20073  pots  up   down                              0                           50/0/73
20074  pots  up   down                              0                           50/0/74
20075  pots  up   down                              0                           50/0/75
20076  pots  up   down                              0                           50/0/76
20077  pots  up   down                              0                           50/0/77
20078  pots  up   down                              0                           50/0/78
20079  pots  up   down                              0                           50/0/79
20080  pots  up   down                              0                           50/0/80
20081  pots  up   down                              0                           50/0/81
20082  pots  up   down                              0                           50/0/82
20083  pots  up   down                              0                           50/0/83
20084  pots  up   down                              0                           50/0/84
20085  pots  up   down                              0                           50/0/85
20086  pots  up   down                              0                           50/0/86
20087  pots  up   down                              0                           50/0/87
20088  pots  up   down                              0                           50/0/88
20089  pots  up   down                              0                           50/0/89
20090  pots  up   down                              0                           50/0/90
20091  pots  up   down                              0                           50/0/91
20092  pots  up   down                              0                           50/0/92
20093  pots  up   down                              0                           50/0/93
20094  pots  up   down                              0                           50/0/94
20095  pots  up   down                              0                           50/0/95
20096  pots  up   down                              0                           50/0/96
1      voip  up   up             [*1-9]...          1  syst ipv4:172.31.86.14
2      voip  up   up             [*1-9]...          2  syst ipv4:172.31.26.37
23551  voip  up   up             2355               1  syst ipv4:172.31.86.14
23552  voip  up   up             2355               2  syst ipv4:172.31.26.37
             AD                                    PRE PASS                OUT
200    pots  up   up                                0                      down 2/0/0
201    pots  up   up                                0                      down 2/0/1
202    pots  up   up                                0                      down 2/0/2
203    pots  up   up                                0                      down 2/0/3
204    pots  up   up                                0                      down 2/0/4
205    pots  up   up                                0                      down 2/0/5
206    pots  up   up                                0                      down 2/0/6
207    pots  up   up                                0                      down 2/0/7
208    pots  up   up                                0                      down 2/0/8
209    pots  up   up                                0                      down 2/0/9
210    pots  up   up                                0                      down 2/0/10
211    pots  up   up                                0                      down 2/0/11
213    pots  down down                              0                      down 2/0/13
217    pots  up   up                                0                      down 2/0/17
218    pots  up   up                                0                      down 2/0/18
219    pots  up   up                                0                      down 2/0/19
220    pots  up   up                                0                      down 2/0/20
221    pots  up   up                                0                      down 2/0/21
222    pots  up   up                                0                      down 2/0/22
223    pots  up   up                                0                      down 2/0/23
216    pots  up   up             11599999           0                      up   2/0/16
20186  pots  up   up             9000$              0                           50/0/2
Jorge Armijo
Level 4
Level 4
-Can you please share the VoIP diagram?
-Also post the configuration.
-Where is connected the IVR?
You need to be more specific, so we can better understand the problem and give you a hand.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Jorge Armijo
Level 4
Level 4
Jorge Armijo
Jorge , sorry for the delay
Finally the problem was some voice ports of SRST, the dial peer match them.
When I shutdown this ports the call can be completed !!!
Thanks a lot !!
