Preference in dial-peer configuration
rochdalemis
I have 8 FXO POTS trunks and would like to assign preference on how they are used for outgoing calls.
I have the following config:
dial-peer voice 80 pots
preference 7
destination-pattern [2-9]......$
port 0/1/0
dial-peer voice 81 pots
preference 5
port 0/1/1
dial-peer voice 82 pots
preference 3
port 0/1/2
dial-peer voice 83 pots
preference 1
port 0/1/3
dial-peer voice 84 pots
preference 6
port 0/2/0
dial-peer voice 85 pots
preference 4
port 0/2/1
dial-peer voice 86 pots
preference 2
port 0/2/2
dial-peer voice 87 pots
preference 8
port 0/2/3
When debugging  with debug voice dialpeer all, I see that all peers are matched, however, when looking at output of debug voice ccapi all, I see that the peer 80 gets selected as a first option while other, higher preference ports are not in use.
Any thoughts?
Thanks in advance,
Greg
Ayodeji Okanlawon
I am not quite sure how to explain it. The default dial-peer hunt algortihm on cisco ro
uters is longest match. The first dial-peer has a longest match especially with the $ at the end of the pattern. Chances are that, this may be the only pattern that will get used. If you want pdial-peer with the higer preference to be used in this your scenario, then you need to change your dial-peer hunt algorithm to preference, followed by longest match.
To do this, configure "dial-peer hunt 2" in global config mode
Please rate all useful posts
It would be just easier to configure a trunk group for this.
https://supportforums.cisco.com/message/1131757#1131757
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Java, the referenced article mentions problems when one of the ports in a group being non-operational.  What is the expected behavior if a port in a group is in use or physically disconnected?
Do port groups affect distribution of incoming calls in any way?
Also, what would be the configuration if I have sets of dial-peers for different patterns and want to convert it all to port groups?
Thanks a lot!
Greg
Greg,
We had this problem in the past and the sets of commands below was the work around.
voice class cause-code 34
no-circuit
trunk group isdn
max-retries 5
voice-class cause-code 34
