Prime Infrastructure Smart Software Licensing
fiza258
I have a consult, I tried to register the license in Prime Infrastructure 3.7, when I send the token, I received a message "Registration failed due to Communication send error.". I searched into the Monitor -> Change Audit Dashboard, and I had an audit description "Failure to establish a HTTPS Session. Reason: Received fatal alert: certificate_unknown ". How do I resolve that issue?
Thanks for your help
Best regards
Fabian
5 Replies 5
balaji.bandi
if you registering with smart License using Cisco cloud, then you need to have prime to be able to use 443 internet access to cisco portal.
you can select modes :
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-8/admin/bk_CiscoPrimeInfrastructure_3_8_AdminGuide/bk_CiscoPrimeInfrastructure_3_8_AdminGuide_chapter_01.html#con_1084193
BB
fiza258
Thanks for the prompt response.
Indeed, I have HTTPS activated in the PRIME, but when I send the token, it generates that message.
fiza258
Attached screenshots of the connection with the URL.
Then looks like cert issue for me :
https://www.cisco.com/c/en/us/support/docs/security/adaptive-security-appliance-asa-software/213932-asa-smart-licensing-failures-due-to-cert.html
BB
Hi Balaji, Are you able to fix this issue?
